What do you use to cut insulation?
ForceFed70
BC, Canada
I'm going to be installing a bunch of fiberglass batt insulation.
I've always just used a box cutter style knife and a straight edge to cut my insulation batts. But got to thinking that there might be a better way?
What have you guys found works the best? Thanks!
Will67
Hell's half acre
I put a **** piece of plywood under insulation and a 2x4 across area to cut and compress insulation down and cut with utility knife. Change blade as needed. For me the trick was compressing it so I was cutting not ripping the insulation.
beater74
I use a cheap serrated steak knife and a strait edge to compress the insulation. the knifes serrations and it's long blade allow you to quickly saw through it on a single pass.
mudhog
south Bygod Texas
the quickest and easy method for me was to use scissors I got some big sharp ones and you can trim it while installing it to go around things. with the knife you got to lay it down and use a board etc. I had insulator dude helping me and before the day was up he was using scissors too.
5.0 Mike
Colorado Springs, CO
OK Don't laugh, but I just finished my 3rd car section of my garage and I cut all of the insulation with hedge clippers. They cut the insulation like butter!! LOL
Milton Shaw
A large gillotine type paper cutter. I think its a 24" cut. Its square and one stroke and its cut. But hate doing it because of all the little splinters of fiberglass you get when you do fiberglass.
djjsr
In the cornfields
Scissors with about 10" blades. I don't know where I got them but they're not very good quality so it may have been Harbor Freight.
nehog
Jaffrey, NH
That's what I use too... Second choice is a big paper cutter as someone else suggested, but that beats the daylights out of the cutting edge.
jlckmj
SE Wiscosin
I set up a 2 X 8 foot wide hunk of plywood or OSB on saw horses so I do not have to keep bending over or work on my knees.
I open the insulation and let it roll out, paper down.
I pull the insulation onto the plywood, cut to the desired length with a short 2x4 and a tile knife or box cutter.,
As I am taking the cut piece off the table, I pull the remainder onto the table so it is ready for the next cut.
Works good, and easy on this 58 year old body.
Jim
Regnar
My neighbor had a nice setup. He set up a work bench on of some saw horses. Took a 1x6 and hinged it off the work bench to compress the installation. Then used and angle grinder with a cutoff disk to cut the bat. Worked like a charm and was quick. He was able to cut about 20 rolls in 30 minutes.
holdover
VA
I use either my very old large scissors which are about 8" blade length ( I think they were sheet metal shears for light duty work like flashing, or a hedge trimmer with the blades stoned sharp. Did my house and a 40 X 60 garage with 6" batts with no problem
Brad54
I have a 8-inch wide, 4-foot long piece of 1/2-inch plywood as a base. I tool a large gate hinge and screwed it to the plywood base. I attached the other side of the hinge to a 4-foot length of 2x4, mounted in the middle of the plywood.
Closed, the 2x4 rests flat on the plywood.
Raise the 2x4, slide the bat in paper-side up, close the 2x4 and it compresses the bat tight to the plywood base. There's your straight-edge.
Run a utility knife across the paper, and with even pressure, it cuts through everything.
A razorblade-type box cutter also works.
I think I might have gone through two blades doing my 32x40 shop, with 12-foot walls. The whole lower half of the walls was 4-footers, so I had to cut dozens of bats in half. I also cut a foot off every one for my 10x10 office with 7-foot walls.
-Brad
Tman
Black Hills of South Dakota
WTF!?!?!?! Fiberglass insulation is bad enough. I was going to make a humorous post about a chainsaw but this **** is just as bad...............Seriously, the glass dust from the cutoff is nasty. Go read about silicosis.
1500hd
Mid Michigan
-Brad
Same theory here but I used a piece of 3/4" plywood with a slot in the middle to compress both sides of the batt. My base is 20" wide and 8' long with the cutting edge 3' from the end. Stanley has a Fat Maxx utility knife with a extendable blade that works great.
jumpingryan
Ontario, Canada
I use roxul mineral wool insulation whenever I re-model.
Slightly more expensive, but it has a slightly higher R-value, fire resistant, and is easy to work with, and easier to cut than fibreglass. I also like the fact that bugs and rodents aren't big fans of the stuff.
As to cutting it, just use a bread knife. In a pinch, I have used a drywall saw.
R
