What do you use to remove tree sap from auto paint?
Jacobson
Does WD40 work?
njride
Isopropyl alchohol, just try it, trust me. Have a clean wet rag and come right behind the alchohol with it.
Soak the alchohol rag with alchohol, it will take very little rubbing to dissolve the sap and wont harm your paint, do test it in a doorjamb first though, like you would anything.
zkling
I'd suggest you use KY jelly, but I use 91% rubbing alcohol or a clay bar.
valentine
Alcohol works great. My son uses those alcohol prep pads that come in the foil packets. They're cheap and you can keep some in your glove box. Single use, then throw it away.
-Valentine
Angry welder
Alabama
I have been told that WD-40 did a great job at taking tree sap off. I have not had to try it, but I was told by several people it worked really well.
njride
Im an auto painter. ..cold soapy water.
By the time you're done you can put in for retirement.
Use isopropyl alchohol, i detailed for a long time, it works, especially on pine sap, and it will not hurt modern basecoat/clearcoat paint, just dont drip it everywhere and follow the alchohol with a damp chamois.
If your worried test it in a doorjamb first, it wont hurt the paint and by virtue of removing the sap in 5 seconds will cause zero damage as opposed to you going at the paint with soapy water for an hour back and forth. Not to mention sand paper, a torch, rubbing at it with bug remover on a scruffy sponge for twenty minutes etc. Just use alchohol, any is better than the above methods, ive found for some reason isopropyl alchohol dissolves it in seconds with hardly any rubbing needed. Hit it with some wax after and your good.
Jokeman
Boston
Isopropol alcohol works the best. Wet a rag and let it sit on the sap for a minute. Then wipe over it a few times. Ive found it works better than laquer thinner and other chemicals
Jarred767
Bend, Oregon
Another detailer here and there's a ton of pine trees here in Central Oregon. I'll add to the list of isopropyl alcohol suggestions. It's the easiest, quickest and doesn't hurt the paint, just wipe the area down after and do it in the shade. It will strip any wax on the car though, so you need to reapply after.
928'er
Wine Country, CA
Friend of mine was preping a car for a respray. After sanding, they had to leave it sit overnight. A "helper" wiped the car down with WD40 to prevent surface rust.
They never could get paint to stick to that car....
Smiliesafari
Orlando, Florida
Lots of pine trees around my place. Removing pine sap is a regular occurrence. I've always used mineral spirits. Quick, easy, no problems with paint.
davewo
USA
Baby oil breaks the chemical bond of pine sap. I have pines on my property and some of them drop a lot of sap that gets in my hair. I can't vouch for what baby oil does to paint, but it removes pine sap with almost no effort.
countryroad82
Kentucky
Prison. Prison is exactly where I would go after I ripped my 'helpers' arms off and either beat him to death with them or drowned him in WD40.
