What do you use to replace grinder wheel blotter paper?
Leviton
Oregon
I'm refurbishing this hand grinder that my son-in-law picked up for me at a garage sale for $5.
I've got it apart and the blotter paper between the wheel flange and the wheel pretty much disintegrated.
When I put it back together, do you have any suggestions on what to use to replace the blotter paper?
Tedley
Coastal MD Delmarva.
By blotter paper I assume that's the paper disc like a shim or cushion? Is that a common correct term for this? I ask because, I would call it a shim because (if I am imagining it correctly) it would probably resemble the shims I use that come with dado stacks, albeit thicker I guess.
Blotter paper was something altogether different, and would definitely not mix well with grinders or dados especially.
Yikes!
Sent from my moto g(7) power using Tapatalk
mike93lx
Richmond, VA
until very recently, i worked at a very large grinding wheel manufacturer. our blotters were a thin card stock, generally. some were coated, some were basic kraft. I'd probably just cut a cereal box for it, as someone else indicated
What is/was the purpose of the blotter paper? Was it a shim, or did it actually serve to blot?
the blotter can serve as some cushion and protection for the machine, depending on the application. generally not necessary, but some customers really wanted them
driftpin
I've used thin cardboard from cereal boxes before. No issues.
I had to overhaul/clean the carb on my 21" Briggs and Stratton engine lawnmower recently, I used a Heinekin 12-pack bottles cardboard container for the carb to head gasket. It worked perfectly. Similar idea, I wouldn't be surprised to see that the thickness of the beer carton is thicker than the cereal box, which would probably lend longevity to it's re-purposing.
A trip to the recycling bin showed that a cereal box and a Heinekin box both measured 1/64".
L
Leviton
Oregon
Gentlemen, thank for the feedback! I will go cut up a cereal box or 6-pack holder.
Congrats on 10K posts, The Cobbler.
mike93lx, thanks for the first-hand experience information.
For those asking about blotter paper, here is an excerpt from the Norton website:
"Experienced grinding operators know the importance of blotters. Blotters are compressible washers that are placed between abrasive wheels and flanges to prevent the flanges from slipping and protect them from wear. They are also important for wheel safety and are required by the safety code ANSI B7.1.
However, even experienced operators may not realize that blotters are useful for checking the condition of grinding wheel flanges.
Since blotters are compressible by design, when mounted they take on impressions from the surfaces of the wheel and flanges. These impressions provide insights into the flange condition and mounting procedures. So next time you perform a wheel change, check for the blotter."
mike93lx
Richmond, VA
No problem. Coincidentally, that is who I worked for.
larry4406
Northern Virginia
I must be getting old...
I saw blotter paper and instantly thought of my high school/college buddies who were into psychoactive non legal intoxicants.
Good info regarding grinding wheels.
L
Leviton
Oregon
Went with the cereal box instead of the 6-pack.
driftpin
I have a bunch of old SF posters, including a 'Flying Eyeball' I bought at Bill Graham's factory outlet, many, many years ago. Owsley! The caricatures used to dispense doses often resembled 'cockamamie' temporary tattoos.
I believe these could also serve as the grinder papers.
