What do you use Vise Grips For
mobiledynamics
Gotham City
I've got a old pair from my pops tool box
With the recent talk of the new Eagles, just wondering what styles do you guys use them for/application? I only grab them when I'm in a bind and need a vise grip plier to clamp on and work some leverage on it. It's not -often- though...
richfinn
Leeds, Yorkshire, England
Mostly as a decent earth point on rusty old vehicles, the teeth cut through rust and grime pretty good and save you time having to clean a spot up or access a battery hidden under a load of ****
I like the Vice grip 7R, it's the only model I use nowadays
d.mcfarland
Western PA
Welding with this style is very common:
2ndGearRubber
Pittsburgh
The 11R style posted above also works very well for depressing single piston calipers. I use them to fight rust seized pads on toyota 4-pot calipers so I can wiggle them out.
My regular style get used most for general gripping of things, and extracting broken stuff that isn't rusted in.
Jlarson
Clamps, I've probably got 6-8 dozen different flavors of vise grip floating around, can't have too many different flavors of clamp when you're fabing.
Also twisting, pulling, removing broken, stripped and rounded stuff.
John T
Years ago I had a 1967 Dodge van with the cable shifter on the dash.
The cable snapped so I put vice grips on the ****** linkage and used a broomstick through the doghouse to shift it.
318 v8
It would roast the tires in a heartbeat
Had a lot of fun with that van…
purplezr2
Central MN
I would look at Malco if you are looking for a good made in the USA looking pliers. I have fondled the Snap on version of them and they are super nice.
Good for temporary replacement window crank handles.
(Not everybody has power windows)
As a Millennial, I can hardly handle the crank windows on my Polaris Ranger. I think the next one will get electric ones.
seagullplayer
Southern Indiana
Pinching off a gas line while you change an inline filter on a mower.
Or add a filter...
Done the same for small airline when working on a machine and we preferred not to shut the air off.
Rounded fastener removal.
Forgottonia
edge of Forgottonia
Another thing Vise-grips are handy for is to hold small items you're drilling with a drill press. Especially short pieces of angle iron or flat iron. This is probably the most common task I use Vice-grips for.
steaks&anvils
Colorado
Holding onto the rusted nut/bolt that is spinning freely through a hole. Clamp it to the back side to keep it from spinning. This also helps to properly round off both ends of the nut/bolt combination. If lucky, the bolt will snap off and save all that extra effort unscrewing it!
Pulling nails where the head has rusted off.
integerspin
Strangest use was as a shifter on an old Panther.
I have a few pairs with tape wrapped around the jaws, they are used as hose clamps.
dscheidt
I broke the shift lever in a land-rover once. Grabbed the stub with a pair of vise grips, which worked fine until I found a welding shop. Guy just laughed the whole time he was welding the lever back together.
Holt
Bellevue, Nebraska
Just used a pair to pull a broke screw out of the wall. The head broke off with just a little bit poking out of the wall
integerspin
I used to drink with someone who's 2A gear lever came out, he would walk in the pub with it over his shoulder. I had to collect the landrover from his house once, to fix the gear lever, crazy thing to drive as the lever obviously rotated freely.
I have just spotted another use of Mole wrenches, they are both Moles, On the bending leaf bit on my sheet metal folder. When I made the folder I put handles on it but had a use for the metal, so I clamped a couple of pairs of moles on it.
1982fxr
Phoenix
All 1970s automotive parts catalogs list vise grips as factory direct replacements for window crank handles.
I've deduced that from my time here on earth.
What?:bounce:
welder4956
Birmingham, AL USA
318 v8
LOL!:rocker:
A high school buddy and I transplanted a 340 from his wrecked 70 Dart ******* into his 66 Dodge van. It was hell keeping a 3 speed ****** together in that thing, but lots of fun to ride around in.
