3100 square foot pole barn with a dirt floor ... getting ready to pour a concrete slab underneath the entire thing. Going well.
I am trying to brainstorm what I will want to put under/into the floor ... so far I'll have an electrical inlet coming in from a PVC riser ... as well as water inlet ... so both of those will be underground and will come up from under the slab.
I will also put a grounding pole into the ground at both ends, since we always seem to need those for electric fences and other weird reasons.
I'll install several drains throughout with pvc pipe going under the slab and out to drainage ...
What else should I lay into the ground ahead of the concrete pour ?
What do you wish you'd had in place when you poured your concrete ?
I am going to have compressed air sockets in 4 spots around the barns interior, but I am not sure if I should build that PVC pipe under the slab ... it would be nice to have it out of the way, but then it's impossible to fix, and I think pipe with compressed air is probably something that needs to be fixed from time to time...
