What fill for grading sloped driveway
vortech91
Recently purchased a house that has a side entry garage that drops 2.5-3' in elevation from the garage door to say 40'- 50' out then levels off. This is a gravel driveway that one day I would like to have a concrete pad for two cars, but for now I just need to add material to bring this up so its not such a slope.
I can get fill dirt for 4 dollars a yard +delivery, crushed concrete for 8 dollars a yard +delivery, or asphalt millings for 8.75 a yard + delivery I haven't priced crushed limestone yet, but do have a quarry not too far. Can I add fill dirt in first to bring the grade up or is gravel, sand, or crushed concrete what I need? What would you do? Thanks for the help!
V
vortech91
Hopefully attached is a picture of the driveway
Chris705
The Finger Lakes of NY
I am going to say stick with stone/gravel & the price would/should fall between your number for fill dirt and crushed concrete....because of the slope of your current drive I advise against fill dirt...because of the taper of the drive...you would eventually want a min. of 6-8" stone base on top anyway and knowing when/were to stop fill dirt presents problems. The two car pad area wants to be very stable and any introduction of fill dirt will make a mess of the relatively thin amount of base material that you need to add at the higher end of your drive.
bczygan
DETROIT! Arsenal of Scrappers
No dirt, unless you are planting a garden.
Any angular (Not round, so not crushed concrete.) material with fines, compacted in 4" lifts.
Crushed limestone with fines is an excellent choice but will be more expensive. It's what I would use.
Bill
