45k BTU Sterling unit heater keeps my insulated (R13/R22, doors) 720 sq ft in the low 70s in the mid Atlantic. It will take at hour to get there from 50* though, and leaving the door open when below freezing temp drops fast inside if open for a couple minutes.
Sterling makes a 30k BTU model of the same heater that would be entirely adequate for that 650 sq ft insulated space a bit south and warmer than here. The big question on sizing is are you leaving it at 50* (min recommended temp for most unit heaters) or off when not in use, how fast do you want it to warm up, and how much will you rollup door be open? If maintaining 50*+ and not opening the door often a 40k may be more efficient and give a longer heater life from longer cycles. If not maintaining 50*+ or opening the door a lot, go with any of the 45k-50k unit heaters for quicker recovery. I opted for the Sterling because they come sealed for separated combustion, there is no upcharge for a special unit.
