sberry
Not rocket science. But this rinse water saddle tank on my sprayer. If finally dawned on me to add a couple brackets and a T with valve in the suction line and I can pull fresh water thru the bypass for some rinsing, I can tap it for hand wash and to rinse jugs,, as a side benefit I have a spot where one tank doesn't do it all and can pull on a bit of make up water. As a side thought could or should find a real sensitive check valve to put in line but I can keep suction on it while switching.
This is going to save me a lot of grief, should have plumbed this on years ago. I can use either 35 or 55 gal tank. It still is amazing even with technology how many of lifes problems can be solved with a welder and a torch.
