Coloshaver
My shop was completed 39 days after breaking ground. (I'll post some pictures when I get stuff moved in) I've decided to do a clear urethane floor sealer and needed to acid etch my 30'x50' floor. I found muriatic acid at Home Depot and bought a $10 garden sprayer from HF. It is cheaply constructed, but if it died I wasn't out much. The sprayer held up fine and after thorough rinsing may get to do bug spray duty. To etch concrete the label on the jug said to mix 24oz of acid to 1 gallon water. A gallon of acid (~$8) did my floor.
My biggest learning was where to start. I figured I'd do it like you would paint - start at the far corner and work out. I planned to do a section at a time using the saw cuts as boundaries. I got the first section done and realized that when I rinse it, I would have to push the water across the yet-to-be done sections and then have to wait for them to dry
So, if you plan to do it, start on the sections closest to where you push your rinse water. That way, the yet-to-be-done parts stay dry and you double or triple rinse the parts between you and your water exit. I figured this out after the first one and the rest went like clockwork.
Be careful and follow the instructions with the acid, but it is really pretty easy.
