What is a safe lubricant for rubber?
Tunar
Woodstock VA
I'm just wondering what lubricant I can safety use on rubber in general such as a hose or an o-ring.
malibu101
Walnutport PA
I have used Sil-Glyde on my weatherstripping in the fall many years. Rub it in and then wipe the leftover off with a cloth.
Keeps them from freezing in our winters and they are still very pliable.
As an example of what I'm talking about. I use it for many purposes.
https://www.amazon.com/dp/B000CIHTPE/?tag=atomicindus08-20
EDIT- I think silicone is bad for O2 sensors. Be careful if it can end up going through the exhaust.
And by the way, auto painters HATE silicone based products.
BillK
Beautiful Southern Maryland
I have a tube of Dielectric grease for spark plug boots that I use for almost anything rubber. On heater and radiator hoses I just use some water or whatever coolant is going in the engine.
Git
S Cal
I use this:
matt_i
An automotive assembly plant can't use silicone because they could never paint a car or truck straight again. But they typically use water based P-80.
https://www.ipcol.com/products/asse...YAihfS9PWMvawz_etevsiMnrPxn6j20EaApevEALw_wcB
Keep in mind there are two major forms of "rubber", the EPDM like you have in radiator hoses and anything for "water service" and brake systems, and then the Nitrile/Buna-N seals for petroleum apps..oil-grease-fuel. There are other formulations, I've seen silicone hoses, but those are a bit more exotic. Best advice is to not get petroleum on an EPDM hose or o-ring, or clean it off immediately as it will cause long-term problems.
Leaflessshadetree
Don't ask.
TRUTH on the first sentence! :thumbup:
Alcohol? Great cleaner, but, it evaporates kinda fast.
Cleaner, yes it will clean. Lubricant or protectant, I'm not sure.
Yes Alcohol as a lubricant. Lasts long enough for the rubber to slip into place without distorting. Doesn't leave any oil or residue.
Who said anything about protectant?
malibu101
Walnutport PA
Never even thought of trying it. Thanks for the info!
Protectant?- No one said anything. I guess it was in my thoughts. Sorry.
