what is best roller type to put down clear aliphatic urethane?
CT2012
Northeast
Am using an aliphatic acrylic urethane (Corotech v500). Surface is not the best in some sections (about 20% of total floor area is a little bumpy and needs some extra care/paint).
I used a regular 9" x 3/8 roller to do the epoxy, it worked fine. Wished I'd have had bigger 18" roller but I needed the shorter one for greater control.
Is it better to use the same size or go with large for final gloss coat?
Thanks for any suggestions.
Shea
California
1/4" rollers work best with urethane since it goes down thin. 9" wide works fine while the 18" gets the job done faster and creates less chances to develop a roller mark.
C
CT2012
Northeast
should i put in on thick? i've got what should be plenty of material, 2 gallons for a 20x20.
or is thinner better? specs call for 3.8mils, i don't really know what that means in terms of how much the roller is pushing around. when i was doing the epoxy, i had about a 1/3 of a can left in the end (i had 2 gallons of epoxy as well). concrete soaked it up more in some spots vs. others (even though i also pre-primed it), but i figured that was going to happen and made the best of it. i didn't have a perfect surface to work with. hindsight i should've used more primer (i only used a gallon), but i didn't know how much it would absorb and was under time pressure to get it done due to pending colder temps and outside moisture/humidity.
Shea
California
Do not put it on thick. Thin to win. Urethane will cloud up and orange peel if you try to put it on thick. That is why a 1/4" roller in most circumstances is best.
Check out this thread here.
tncatadjuster
Memphis, TN
I like to use 3/8", requires a little more attention but 1/4" just can't cover area quickly like a 3/8", and leveling can be a chore with a 1/4". Buy the best cover you can this is the finishing touch to a lot of work. Shed resistant ultra whatever.
Compute the area and do not put it on too thick as stated, it will be a soft surface in thick areas.
metalwork72
I just coated my floor with two coats of Legacy's Slow cure polyaspartic 80% solids coating over top of epoxy primer using 3/8 rollers. 900sq ft. 4.5 gallons of primer. 5 gallons of poly on the first coat, second took 2.5. No roller marks. Awesome sheen.
Shea
California
Let's see some pictures :rocker:
C
CT2012
Northeast
shea i ended up using 1.5 gal's for 400 sq. ft., with a 3/8" roller.
turned out great.
thanks for the tips.
metalwork let's see some photos of that job, it sounds like the surface looks like glass!
