What Is It? Clamp? Tool Stop?
fasteddie
I've had this thing lying around for many years, never knew what it was for. Looks like a stop or indicator pointer that clamps on a dovetail shaped bar. Hardwood with brass threaded rod, knurled brass knob. Looks like it might have had a nameplate where the 4 holes are on the back.
Ecosta777
Threading stop for a lathe. Mounts on the cross slide ways and allows you to bump the cross slide against it at zero instead if trying to dial back to the correct zero when threading.
Sent from my Pixel 2 using Tapatalk
readhead
Durango, Co.
I have a later version just like that made out of aluminum. I think there are some pieces missing and they come in pairs. It is half of a set of trammel points for laying out circles. You supply your own stick with similar bevels on both sides. It looks like there is a scribing point that is installed upside down.
