What is it, part 25 or 30 or …
Old tool guy
Anybody recognize this? I know what it is, just checking the knowledge base.
O
Old tool guy
Not for lifting a thing for moving?
It is, but it has a specific purpose, whereas your picture is of a crude heavy duty pry bar. Not crudely made, but meant for rough use. My picture is a more refined tool.
rust in the eye
Chicagoland
Clearly a lever. looks like a fancy johnson bar("crude heavy prybar") to me too. The interchangeable tool at the business end is interesting.
Similar devices are sometime used for lifting formula race cars, this appears too tall for that. I'm with bcschief.
"part 25 or 30" ??????????
Looks like the tool I use to move My Laguna bandsaw around. It has two fixed back wheels, mine becomes the front wheels.
PCustoms
VT
I know some millwrights who would like to give you a lesson in rough use....
So what special task is this magical device made for?
BTW the bearings/wheels look a little off...
O
Old tool guy
bcschief got it. I’m managing a series of projects for a large pharmacy chain, renovating some of the shelving and the checkout lanes, plus other stuff. Some of the shelving units are new, some are skated into new positions. You remove the bottom shelf and toe kick, get two or more of these bars, and it’s fairly simple to move 30-40 ft sections of shelving in one piece.
PCustoms
VT
Yeah, that sounds way more refined than what the tool in post #2 is used for...
Must be special because "farmacy"
mreisner
North of Detroit
I've moved some pretty delicate machines with that like a Bridgeport mill and a South Bend Lathe.
O
Old tool guy
Update. Here are pics of skating a shelf unit, and closeups of the skated. They have 4 low profile casters that go under the feet. The pry bar thingie is used to lift the shelving enough to get the casters in place.
Wrench97
Southeastern Pa
Post #2 is what we called a Johnson bar we used it to get stuck forklifts out of trailers like when one rear steer wheel falls off the side of the dock plate......as the terminals got larger and everything turned into pallet loads then we had multiple forklifts at one location and just used another lift to get the stuck one out.
PCustoms
VT
That's one hell of a refined furniture dolly
O
Old tool guy
Very heavy duty, considering they move 18-20’ long x 66” high loaded shelves. Hope my wife doesn’t see it, she is forever using those flat sliders to move furniture.
O
Old tool guy
I work with different contractors, different crews, some better than others. In post 24 you see a good contractor using a quality tool to relocate, or skate, shelving. Here is a pic of a different contractor who i give credit to for getting the job done, with less costly equipment.
