What is it?
BQuicksilver
So after pulling this thing off the cold water line to my old sink, I've had a few friends come across it and nobody (myself included) knows what it is.
It's heavy (brass?) and seems to have a valve of some sort and an electrical connection (which wasn't connected). I think it also reduced the pipe from 1/2 to 3/8". No idea what it is. I fgure if it's an odd item I may send it to TOH for their "what is it" segment and you guys will have an inside line.
hofferwood
DownRiver Michigan
It's a "Flow-Switch" turns on or off when water flows. (power)
Why there, who knows perhaps just needed a coupling, and that's what he had.
billp603
NH
Could it have been the starter for an old well pump that did not have a separate well-x-troll type pressure tank? When the pressure increased from stoppage of flow it would shut the electrical feed to the pump.
Hondarider
Adams, MA
The way the switch is actuated makes me think its a flow switch. There's a pivoting arm that you shouldn't really need for a pressure switch. Most pressure switches simply "T" off of the line and dead end at the switch. The position of the pivot indicates that there is something in the path of flow that actuates the lever arm. That being said, I cannot imagine why you'd need a flow switch in the kitchen. A pressure switch and a pump make sense, but we generally use flow switches in applications where flow rate is critical to cooling. It certainly has plenty of adjustability for the pressure required to open or close the switch. I've never seen anything like this.
