What is it?
Old Man Roger
Palm Coast Florida
Anybody got a clue what these are? I thought they were some kind of vent but they’re blocked off. I followed one that went through the ceiling right next to one of the sewer vents, but no idea where it goes after that because it’s inside of a wall I believe.
They’re in my attic, the house is in south Florida.
gmcgeo
only reason for running into attic space and through roof is for a vent or drain. seeing that is capped off would tell me it is no longer in use and easier to cap it then start ripping it out.
if you have no issues i would not mess with it.... or try to get a hold of previous owner and ask what it is
Jinks
Daytona Beach
I can't imagine any kind of solar water heater that would use that size pipe. Mine has one feed, & one return, both copper & the same size used to feed a normal sink.
gmcgeo
It's interesting that the pipe looks like it's been exposed to the sun.
Thats what i thought at first, i wonder if because in Florida and pvc in the attic if it got hot enough to discolor?
O
Old Man Roger
Palm Coast Florida
The previous owner passed away.
it doesn’t look like it ever went through the roof, I don’t see any holes. The roof has been replaced though, so the plywood may have been replaced.
FredWanaker
NorCal
i concur - solar water heater, for the house or a pool. The larger photo shows those pipes are much smaller than the vent, and the spacing of the two are about what we see in older solar water heaters around here.
steve308
Was there ever an AC unit up there? Could be piping for condensation draining.....just a guess.
O
Old Man Roger
Palm Coast Florida
The air handler has always been in the closet downstairs.
If it was for solar hot water wouldn’t it just run to the water heater? These things go off in all different directions up there
thammel
Maryland
Looking at the maze of pipes up there...I see some gray conduit "pipes". Perhaps the solar hot water is the best guess. And check and see if the capped pipes are cpvc or pvc. (can tell this by inspecting closely the fittings for markings). If CPVC, then the solar heated water is probably correct.
Pate
New York
I know when I built my house I had PVC pipes run from the basement to the attic for future wire runs.
GreenIron
A bit north of the GOA
I'd have to say it is for, or was for an attic installed water heater.
My previous house had a 40-gl. water heater in the attic and had CPVC for the HOT side and PVC for the COLD side.
The water heater was either remove from the attic and the lines plugged, or the lines are there for a future water heater use.
O
Old Man Roger
Palm Coast Florida
GreenIron, an attic mounted water heater seems like it could be the answer. Because it does seem like the pipes run to both the bathrooms and the kitchen.
And now that I think about it there was some heavy duty bracing up there that didn’t seem to do anything. That’s probably where the water heater was mounted.
There are two gray conduit pipes right next to that area also that probably ran power to the water heater.
I knew someone on this site would know what it was lol
PassnThru, there is no crawlspace, it’s a CBS house on a slab. The rafters and roof are wood, but the rest of the house is concrete block.
O
Old Man Roger
Palm Coast Florida
And I guess, in a way, having your water heater in the attic in Florida is kind of solar heating lol Great idea until it leaks, and we know all water heaters eventually leak.
JRC3
Southwestern OH
As I recall the CPVC pipe I worked with 20+ years ago was Grey.
That was probably Vanguard. Lots of damage and eventual class-action with that product.
When I saw the grey whatever in the background that was the first thing I thought of...Like maybe a water heater was replaced and placed outside and PB pipe was used while the CPVC was abandoned.
Or maybe the grey Vanguard was replaced with the CPVC years ago...Then, the attic tanked water heater (WH) was replaced with a tankless and was placed outside or somewhere else and the CPVC was then abandoned. OP, is there a tankless outside or in some other location possibly not original of the WH?
GreenIron
In our previous house, the water heater (40 gallon) was in the attic. I had the builder installed a large pan under it with a capacity of 15 gallons. A 2" drain line ran from the pan and exited at the house's front overhand with a 90° and short tattle-tail line. If the water heater ever developed a leak, it would run out and exit at the front of the house. This would allow me to notice it and react to the leak. We lived there for 26 years and never had an issue.
We live in southeast Louisiana and the electric elements in the water heater didn't work very much with it in the attic to heat the water.
O
Old Man Roger
Palm Coast Florida
Now look for the electrical service to the hot water heater.
I emailed it to my HVAC contractor friend in Wellington FL to get his opinion.
The water heater is now downstairs in the closet underneath the air handler.
it has a conventional water heater but all of those pipes in the attic are still being used, it looks like they just re-located the water heater.
I’m glad to see you mentioned that the CPVC wasn’t the bad stuff, half the pipes up there are PVC but some of them are CPVC. I remember the class action lawsuit with that gray pipe, a lot of people took the check but didn’t replace the pipe lol
Well my water heater is no longer in the attic, but I had a problem today lol I moved a board and broke one of the CPVC pipes!! That’s how I knew those pipes were still being used. I got the water turned off pretty quickly though and minimize the damage.
I was putting down some flooring so I could have a little storage space up there. The first picture you can see some of the flooring I put down, the second picture Shows me pointing where it leaked.
GreenIron
Roger(Old Man), :) Glad you got the water leak stopped quickly, without too much damage. (y)
I too laid flooring in the attic of my previous house. It's nice for storing thing and makes it easier to get around the attic.
In our new house, the builder laid down flooring in the attic, so I didn't have to do that. Of course, nothing is going to be stored up there. Everything that we used to store in the attic will be stored in the garage's mezzanine.
couch67
Ontario Canada
Ah that explains the fan in the first photo! I was going to ask about that...
TRWham
East Cobb County, Georgia
CPVC does get brittle with age but is not an issue if it is undisturbed. When working on a CPVC system, be careful not to move any existing pipe that will remain, and use an appropriate tool to cut old pipe (i.e. not shears). Occasionally you might run into CPVC fire sprinkler pipe that is distinctly orange in color. PVC will be white and CPVC more beige.
