What is liquid tefflon ?
tandnhome
Mississippi
On the Hein Werner jack rebuild from Elroy he used liquid tefflon, to seal the tank.. What is it and where can I find it?
Stephenw
Utah
I use the Permatex brand. I got it at NAPA.
tonydanzah
the champagne of people
this is liquid teflon.
Elroy
kentucky
Well why don't you ask Elroy?
Elroy used Loctite #567 to seal the cylinder to the main body on both the WS AND the O'Boy/OS jack builds. This joint is at the high pressure end of the cylinder. Hein-Werner augmented the metal to metal seal developed by seating the cylinder into the main body with an o-ring on the WS jack where the O'Boy relied solely on the metal to metal seal and the threads.
That be it.
There are a lot different threads sealer you could use. Elroy just happened to have that particular thread sealer on hand so it got called into duty. Any Loctite dealer should be able to fix you up.
