What is the correct name ...
... for small female thread metal fasteners that you press into plastic or wood that accepts a machine screw instead of just using a coarse thread screw.
bugnut
Central Ohio
*** bolts
https://duckduckgo.com/?t=ffab&q=***+bolt&atb=v226-1&iax=images&ia=images
and no this is not a joke
mcmaster or google
joe_padavano
Northern VA
*** bolts
mcmaster or google
Not quite. *** bolts are used where you need matched male and female threads on a through fastener. Typically they have slotted screw heads on both ends. They are not threaded inserts.
ducksface
Those are book binders.
They were used to bind unbound documents.
I've never heard them called *** bolts.
Shiftless
East Bay SFO
An interesting sideline to the original question but...
McMaster-Carr lists quite a few variations of “*** bolts”.
Here is a bit of their selection.
gnpenning
I have more questions than answers.
Great examples of things being called different names but being essentially the same thing. *** bolts, Chicago screws, etc.
I will say I don't know if if seen *** bolts with decorative heads but Ive seen many examples with Chicago Screws, while both can be plain.
https://www.amazon.com/dp/B074BBXKVM/?tag=atomicindus08-20
As mentioned depending on what you are putting the insert in and what it's holding you have options.
ttpete
Dearborn, MI
Chicago screws are used in leatherworking, mainly for straps and belts, and for attaching belt nuckles.
