What is the difference between a buffer & grinder (hand held)
fred d
Metro Houston Area
I have multiple 4-1/2" grinders.
I also have a 7"inch grinder.
What is the real difference between a buffer and a grinder?
RPMs? Variable speed?
I'm wanting to get a buffer to be able to buff vehicles paint with. Can I use something I already have, or do I need something different?
Why?
If I decide to buy a buffer, electric or pneumatic?
Why?
I have a Quincy compressor with a 80 gal tank if I go pneumatic
Thanks in advance
JDweld98
To my understanding buffers don't spin in a perfect circle like a grinder would. They move a bit to help avoid getting circular patterns and gives you a more consistent looking polish. Hopefully that makes sense... I'm not always the best at describing things. [emoji16]
larry_g
oregon
creativecars
Indiana- where horse and buggies still roam
In a word... speed
The grinder version of similar tools will spin twice as fast as the polisher.
Electric or pneumatic will both work well, I prefer air as I have a better control over speed by modulating the trigger, and still have enough torque to keep the pad moving.
Too fast will burn the paint off quicker. Practice on something that does not matter because once you burn off the paint there is no good fix with out refinishing.
DTE
North Carolina
I do not do much work any more but I have wet sanded and buffed hundreds of cars in the past. I still have 2 Makitas and for me they are very smooth, variable rpm ( plus as mentioned above you can control the speed by bumping the trigger also ) they have a really smooth trigger that allows you to start the machine slowly or wide open. And it will last for years.http://makitatools.com/en-us/Modules/Tools/ToolDetails.aspx?Name=9227CY
2oolhound
BC Canada
Looking at it from the other direction buffers don't have the amperage. They'll bog down and stop if you try to grind with them. Just thought I'd mention it because a lot of people try to sell buffers as grinders.
DTE
North Carolina
I have never done it myself but I see where a lot of guys do the sanding with a DA, I always done my work by hand with water and a small 3M rubber sanding pad . not a block
