What is this air tank fitting?
1190R
Just bought a used 300 gallon air tank
What is this fitting?
1190R
Thanks guys
ArchT was right
I thought it might be some kind of crazy valve but it's just a barbed fitting
Firebrick43
West central Indiana
Does your tank have a legible ASME certified data tag on it?. If not, it is not a reliable air tank
With that fitting someone has been using it for something other than high pressure air.
1190R
It does
Going to hydrotest anyway
1190R
I want to replace the barbed fitting with a double tapped bushing for an auto drain valve
Which one of these is better and why?
OccupantRJ
Eastern North Carolina
Those are generally called reducing bushings. A drain will need to be on the bottom of the tank. Are you planning to lay that on it’s side? It looks like a vertical air receiver used in industry designed to stand on the mounting ring, so the drain would likely be on that end. I would also want a pressure relief valve at/in it somewhere. I hope you have a rather large air compressor with a decent duty cycle.
1190R
Correct. Tank will lie on its side and yes. I got a 5 hp IR rotary screw air compressor
Relief valve present
