What is this automotive electrical component?
slowtwitch73
Hellgate
Trying to sort the wiring on a Willys... what is this unit called? Tried various searches with no luck. Any other info as to purpose etc appreciated.
AA/FC
It drops the voltage to the ignition system.... It been a long time.... I'm sure others will chime in. But if I remember correctly it drops the voltage going to the coil from 12 volts down to like 9 volts. (roughly)
Just google "Ballast resistor" and you'll get all the info you ever needed. lol
unslow1
Illinois
I carried a spare for years. Tell the parts house you need a ballast resistor for '69 Charger and they should get you a match for that. I haven't had to get one of those since last week.
slowtwitch73
Hellgate
No not original.. '53.
I'll have to look tomorrow... cant remember for sure where the wires go...
The green wire comes from the starter solenoid. I think the yellow goes to coil, can't recall on the red.
No gauge cluster.. all individual gauges.
Anyone with a Chrysler product from that era had AT LEAST ONE spare in the glove box !
RPH
Michigan Thumb
Purpose is to save the points from burning up from excessive arcing at 12 vdc. Small voltage drop in coil primary didn’t hurt the run mode in the engine. At start you needed a hotter spark so 12 vdc was fed direct to the coil primary.
