What is this Brown & Sharpe tool?
Mick56
Janesville Wisconsin
Picked this up at a sale, the tag they had on it says Caliper Gauge Measures Depth Metal Hole. At zero, the stem is extended to.75", when retracted it is at .25", so it has a range of 1/2". The back end looks like it should attach to something? Googled awhile but could not find this tool.
gorilla
I'm not sure of the proper name for that but looking at the label on a brand new one it's called a micro-controle. It's not a measuring device per say but a micrometer head used to control motion on some unknown device. Sort on a mini version of a leadscrew on a lathe.
Corndoggeh
Agreed with others, you use that on a arm/jig/anything that needs micrometer adjustments. For example Ive used them on arms that carry sample pucks in vacuum chambers. Micrometer adjustments are critical to aligning multiple arms together to transfer a puck through long chambers.
