What is this clamp thing?
Odd Job
British Colombia
Picked this up at the flea market a while back. I've used it as a helping hand clamped to studs when fastening horizontally. Not sure if that's the intended function. Thought also might be a bench stop? Only stamped markings read "No 1" and "1 1/2" The clamp is meant to bite into wood having a raised + on the contact surfaces. All I know for sure is that I had to have it.
Mintgrun
Kingston, Wa.
I think that is the stationary half of a "bar clamp" which uses a piece of lumber as the bar. I have two sets like this.
The little piece of wood they're on is just for storage and the other two are at the other end of the stick.
Tom
Mintgrun
Kingston, Wa.
I stumbled across this thread while starting a new one for another clamp what's-it? This one may have had a similar purpose, or was possibly for something specialized.
The only markings I see say DRGM, which indicates that it was made in Germany prior to 1945. The clamp portion only opens up 3/8", or even a little less.
Has anyone seen one of these before? I don't think it is a saw set! My guess is that it uses a piece of wood to make a clamp and the other half of the tool is missing... if there was one.
Tom
steaks&anvils
Colorado
Wouldn't that ******/stud on the clamp pad leave a mark on the object being clamped? This would suggest it was not for fine finished work?
Maybe for boat or coffin making? Although, I think the coffin clamps have their own steel bars. And both, I would assume to be "finish" grade so that pad issue would rule them out?
scaffolding maybe?
Mintgrun
Kingston, Wa.
tom, that tool looks like it is for stretching a fabric over a frame. Perhaps for paintings, screen printing, or ????
I think you are onto something. I am now thinking it may be a strap, or webbing stretcher. I'll do some more searching online with that in mind.
I have a Bessel which uses the little 3/8” gap to clamp to a larger clamp, like an F clamp, then is used to clamp a face. Your arm may keep the item being clamped from drifting down.
Bessey clamps are awesome and made in Germany as well. I don't see what function the long arm would serve. or the grippy surface on the narrow clamp pads. I do see the similarity though and the ones that I have came to mind when I found this one. I'll snap/post photos of those later. I also have a few other "Clamp what's-it?"s to share.
I am still trying to figure out the reason for the long arm on the clamp. It may help keep the clamp from rolling up over the top when a strap is being stretched over a frame. Googling hasn't supported my theory yet, though.
Thank you for the thoughtful input.
Tom
Mintgrun
Kingston, Wa.
Here's another mysterious clamp thing. At least it has more markings to use a clues. (sorry I did not measure it, but the lighter colored board is 3 1/2" wide).
When I searched that date using the tool patent site in the sticky, I get this error: 1919-03-02 was a Sunday not a Tuesday.
That one has me stumped.
These look like they have a special purpose, but what might that be?
Tom
don‘t you love it when a company is so enamored of their product they put the wrong date on it? What is the middle letter of the name? We?er….
the DATAMP date error page will let you input partial dates, like Mar 1919, or 02 1919, to see if they just pooched one field. But unfortunately, we can’t be sure if that was patented as a clamp, or was a clamp on a hacksaw, that happened to be big enough to show off the date.
Mintgrun
Kingston, Wa.
WEAVER. Searching the name and numbers on the tool did bring up a few rifle scopes... but that wasn't very helpful.
He was off by a year. Mr Weaver was very prolific in that time. I put in Weaver as the company. Part of a bearing puller clamp.
Mintgrun
Kingston, Wa.
Thank you for the information. You have very good hunting skills!
I guess the patent should read 1920. I wonder how he made that mistake.
Mine will make a good paper weight, since I doubt I will ever come across the other missing pieces.
I'd been wondering about that one for years!
Tom
