What is this? Copper Plated Hole thingy?
Mohawk Dave
SoCal
Sorta looks like a rivet hole finder, but I don't think it is. Welding?
Rather light duty, Made in Japan. Copper plated Steel.
The solid end fits snug into the hole opposite it. There is a *** on the back side of the solid end.
any ideas?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
At first I thought a die except for being made out of copper, then again, the copper if heat treated to where it is springy could be an eyelet die. It wouldn't be a spot welding fixture because it would have to be separated and not on one piece of copper.
My guess is a die for eyelets. :dunno:
Rookie2
Western Pa.
I would guess that it makes washers from some soft material . remember three ring binders that you had to put those sticky 'O' rings on the papers.
Nah, you got me !
I'll go with ZKling !
rlitman
Long Island
It is a grommet die. And it is not made of copper. Just copper plated.
Provincial
Near Salem, OR
Does the tool fold fully the other direction? If it does, and the sharp-edged cone that shows in the first photo fits into the recess with the *** on the back, it could be a punch to make the hole (located by the ***) before reversing the tool to insert and set the grommet.
Copper, because it looks cool! Actually, probably a color code for size.
It is not a rivet finder because the male part of the die set prevents using a drill to transfer a hole.
Mohawk Dave
SoCal
It does not fold backwards. It stops at 90 degrees.
ScottsGT
Lake Wateree, SC
Interesting tool. I would have just drilled the hole from the other side. Of course all situations are different. I'll have to store this one in the memory banks.
zkling
It's probably just copper washed for corrosion resistance. Won't flake like chrome and holds up better than paint. IF it is just a rivet hole finder, why are the surfaces concave?
Dave even mentioned in the first post that it is not copper, just copper plated steel.
I really think it is a light duty die, the stamped raised portions not only add stiffness to the beams, but also make for a hand grip.
IF the '***' on the back/bottom side is flush with the folded over piece I'd guess it was a manufacturing aid to help locate the lower pressed in piece. :dunno:
logical
Northern fringe of the Motor City Suburbs
I think the *** holds the fabric in place while the sharp area pierces a hole in the fabric and the curved areas set the two halves of the grommet. I have one and it's used to put two pc. grommets in a tarp. You place the grommet halves on either side of the tarp, line the *** up with your mark and whack it with a hammer to simultaneously trim a hole out of the fabric and form the two halves of the grommet together.
Mine has a separate punch and a thru hole in the tool allowing you to create the hole in a separate step, like this one shown. Yours either does it as one step or is missing the punch:
Mass
:beer::thumbup::bowdown:
Mohawk Dave
SoCal
Well gentleman. Logical is the winner. That's definitely the same thing he pictured.
All my grommet stuff is CS Osborne and more heavy duty, thus I wasn't sure what this was.
Thanks guys!
logical
Found mine (with original dried out "touch it and it splits" pouch). Like I mentioned I haven't used it for decades. After finding it I remembered that the punch is used separately before installing the grommet, it doesn't fit thru the hole in the crimper die.
Mohawk Dave
SoCal
Right on.
I threw mine in the "Grommet Box" but have a feeling I'll never use it as I have the CS Osborne set and anvil type.....But who knows. Maybe it's great for certain situations.
