What is this hand-made handle (?) for please?
IainP
Hi all. I saw this at an antiques fair in Lincolnshire UK, yesterday, and wondered what it was. It was a bargain at £1.50 ($1.80) and I bought it knowing that someone here would be able to tell me what it was for! I'm assuming it was some kind of handle, but it's so crudely made, I can't see how the "teeth" could engage with the whatever it was supposed to connect to.
Iain
I
IainP
Interesting idea! The edges are quite blunt though:
Farmer J.
UK, Cornwall/Hertfordshire.
It looks familiar to me, I'm sure I have seen someone using one somewhere..!
I don't think it's necessarily a handle, it could be to retain a roll of twine on a shaft or something like that.
The iron ring looks like it has had hacksaw cuts made around the inside of it for some reason, I don't think those are original.
I
IainP
Yes, I feel that way too! I'm imagining some kind of rural/ farming use now, but no closer to a solution. The 15 minutes I just spent looking at "antique rope making machines" on Google images was fun though.
Farmer J.
Ha ha, yea, those rope machines are great fun! I was thinking along the lines of an object like this maybe sliding along and separating the strands as a cable is twisted..
Coming from Lincolnshire it could likely be something rural or to do with farming. Will keep my eye out.
Does it have any wear marks at all, like grooves or scratches, that may give a clue to how it was used?
I
IainP
Ok. some more information and pictures!
Yes, on the side away from the metal, the wood appears more damaged than the top side, though whether this is just how it was made is hard to tell.
There's no obvious sign of wear on it, not even in the hole, but I hadn't noticed before that the metal ring is off centre, so the teeth are nearly flush with the wood on one side and sticking well out on the other side.
This seems very odd, as either the teeth perform a function which involves them sticking out away from the wood, or flush with the wood, but it's hard to imagine what function it could perform doing both.
The 2 nails go all the way through the wood, and have had the points flattened off, as you can see in the photo. This suggests that the ring had to be held very firmly in place to perform its job.
The item was on a table along side other very old and "rustic" looking tools such as saws, and other wooden tools.
One thought, though this looks kinda bit. There are tools to "groove" dowels to improve glue adhesion. You can buy pre grooved dowels, or you can groove your own, crudely. Unless someone had tiny hands, this seems too big.
Other uses where adding grooves to something might be useful. Since they aren't symmetric, consistent, or anything like that, an "out of sight" application?
Farmer J.
A couple more questions, to at lest try and guess the age of this object.
Are the nails wire nails, cut nails, or hand forged ones? The use of clinched over nails suggests it was made before around 1800 when machine made screws came in to common use, (invented in 1760) but if they are machine made wire nails the same as modern ones, then it was made after around 1860 and the maker just preferred using nails to screws.
Any idea what species of wood it is? I don't immediately recognise it, it looks rather splintery. If it's a non native species, some tropical hardwood, it may be that it was made somewhere far away from Lincolnshire.
Marsim
Could it be something along the lines of this cheese press handle?
Thesian
Maybe a stretch, but just a wooden mallet, and the teeth were a way to hold the handle in place with pressure?
I am along this same line. The teeth are too irregular to be any kind of effective drive mechanism. I would then assume they either cut, or hold a position. My guess is also that it’s some sort of mallet head with the metal piece being part of the fixation, albeit a sad one alone. My 2 cents….
I
IainP
Interesting ideas here! I'm trying to get one of the nails out now, so will post result here. Yes, the wood looks splintery at first glance but actually is rock solid, and very dark, so I'd guess it's non-native.
IT reminds me of a bore auger handle.
I see what you mean:
Nevadablue
I think it was made to encourage conversation. A “conversation piece”. Put it in a place of pride and wait…
what fun, watching for more ideas!
I
IainP
Ha you could be right. I'd love to know what it is of course, but also rather happy that it's not embarrassingly obvious either, and has generated some great discussion. And I've learned about old nails too ;-)
Iain
In the hammer camp questions: does it look like the ends have hit anything? MY plane adjuster hammer has small indentation from hitting wooden planes. A non native hardwood may not show much damage.
In the other questions camp: are the end tapered evenly? Does it show sliding damage on the cheeks vs on the striking faces? Maybe to push something open, or to form leather or….?
Farmer J.
Iain
This is one of those times when the saying 'It's about the journey, not just the destination' probably applies!
If you haven't already found it Stumpy Nubs did a very good little video about old nails:
I
IainP
That was very interesting, thanks!
No wear or damage that I can see. Here's a close up of the ends.
I tried to remove one of the nails but it didn't go well.. It looks like a normal wire nail though:
Farmer J.
I wouldn’t think it is for twisting, because there’s only two nails holding that metal piece on.
Going off on a wild tangent. How about for a spinning wheel or yarn winder?
Yea, I agree, it looks like something like that. It could fit over a shaft and retain a coil or spool of yarn, thread, string, rope whatever. The metal washer would prevent the retaining pin or wingnut on the end of the shaft from chewing in to the wood. Used like this the nails holding the metal washer wouldn't be under any significant strain, they just retain the washer in place.
CN Spots
NW Mississippi
Had to google the yarn winder. Most have straight or concave ends. Seems like this thing's taper would encourage the yarn to fall off?
This is a good one. I have no idea. It'll probably end up being a clammerbob for a bevelling tacklasher.
and don't bother googling that.
Leviton
Oregon
I'll throw out a wild a** guess. Could it be a homemade tenon cutter? First cut the end of a leg or spoke to roughly the right size, than spin this on to clean it up and make it round and the correct diameter?
What doesn't fit about this theory is that usually tenon cutters have only a single blade, whereas this has multiple "blades". I think the only way to know would be to try it.
However, my speculation is pretty much closing the barn door after the horse has bolted. I think CN Spots has correctly identified it - it has to be a bevelling tacklasher.
