What is this Huge Magnet for?
woodgate
I bought this at a garage sale for $5. It literally weighs about 40-50 lbs. The bottom is not magnetic so I'm guessing it is lined with lead or something (also adding to the weight). The whole case seems to be stainless steel, and is seamless. The top is a super strong magnet! The guy said he had it in his boat to hold his keys, but what is it really?
There is a tag on the back that is totally illegible, and the only numbers are
78160 SAN1 944
klaus
BC Canada
It looks like it is to remove the security tags from clothes at a retail store. It would be built into the top of the sales counter.
GRX
MD
Lead does not block magnetic fields far as I know. The retail store idea sounds likely. So what are your plans for it?
W
woodgate
Is it actually a marine key holder!? And if lead doesn't stop magnetism how the heck is SUPER strong on the top and basically has no magnetism on the bottom of it? Does any material block magnetism?
neophyte
Pennsylvannia
If used right I believe a thin shell of highly magnetic iron can block magnetic waves or at least redirect them. I'm not certain how the iron it would need to be positioned around the magnet to properly work though. There's a Wikipedia page that mentions magnetic shielding. http://en.wikipedia.org/wiki/Electromagnetic_shielding
gorilla
Their is a material called Mu metal (not sure of spelling) that is used to block magnetic fields. It looks somewhat like lead and is quite heavy and expensive. I think that you have a magnet that was used to direct an electron beam in some kind of scientific measuring device.
GRX
MD
Blocking magnetism - interesting topic for discussion. Yeah, I think neophyte hit it. Someone more knowledgeable than me can surely explain it better. From what I understand a ferrous material (contains Iron) is used to re-direct magnetic fields around objects, or nullifying them. Also, counter acting (opposite polarity) magnetic fields are created with electricity. This is how our computers work without internal components interfering with each other.
>edit:
You are right gorilla. Your post about Mu metal got me thinking so I did a search. This page explains things pretty well.
>> http://www.newton.dep.anl.gov/askasci/phy99/phy99x89.htm
pendragon1998
NE Georgia
I keep super magnets out of hard drives for use in the garage and occasionally for other things. They seem to have a magnetic side and a non magnetic side, so something is blocking the magnetism.
Edit...well dang, you made me look it up!
Edit 2...GRX out-googled me! lolz
GRX
MD
^^ lol ... funny we arrived at the same page pendragon. The rare earth magnets from hard drives are made from neodymium. Not sure why they are so directional. Perhaps the steel backing. More Googling required. They can be fun. I have a whole stack of old drives I am about to open with the grinder actually. :D
MikeYC
Da' Burg Virginia
It's a Docking plate for a hatch cover off a NUKE sub. Magnet is very powerful and usually takes several to remove from the deck. Used to hold SDV chambers on deck.
pop pop
Virginia
Looks like an access cover for a nuclear reactor. Probably radiated. Lined with unobtanium so it isn't magnetic on one side. Might be radioactive though.
GRX
MD
Unobtainium. Would love some for my shop but can never seem to get hold of any. :bounce:
Professur
Mo-Ray-Al, K-bec, Ka-Na-Da
I've got a ton of these magnets. A grinder wouldn't be my first choice .. but you'll figure that out quick enough on your own;). For taking the backing off them ... I have trashed several trying to use a simple heat gun to loosen the glue. Those magnets are very temp sensitive and temp fragile. The heat gun didn't top 400f, but those magnets are powerless now.
iajonesy
Iowa
We use that same type of magnet to remove steel material from incoming grain trucks and trains as the grain passes under the magnets. You'd be surprised at how many pliers and screwdrivers,nails, screws,and other **** ends up on the magnets. Never any good tools,though,because most farmers buy cheap **** to use in the fields.
Mike
Jagmandave
Overland Park, Ks.
Yeah, we had those magnets in our pneumatic conveying tubes, they were so powerful they'd pull the iron out of the flour.....as in iron enrichment, not nuts and bolts.
GRX
MD
Thanks, I know what you mean. Already have a few HDD magnets on the side of my toolbox. You can practically hang a bench vise on them. The grinder is just to remove the swedged rivets on the outer casing. Found an old 5.25" form factor Quantum Bigfoot (remember those?) in a box of my late father's PC gear. Should be interesting to see what the guts look like compared to the newer drives.
W
woodgate
Man I can't tell whose messing with me or not! I guess karma is getting me back for telling my students to use "striped spray paint" today. (I'm a shop teacher)
Zelatore
Walnut Grove, CA
"we always use a three man crew when handling these magnets"
Ok, I get why - something with 1200 lbs of pull could certainly be dangerous, but how the heck do you even get three guys on the thing? It's small enough to fit in your hand. Seriously, I don't even know HOW you handle something like that. Seems like it would be near impossible not to get something stuck to it / it stuck to something such that you just weren't going to separate them.
bmw57isetta
Austin, Texas
If you're tearing old hard drives apart to get those rare earth magnets, put the drive or component that holds the magnet(s) in the freezer for 30-45 minutes. They'll pop right off with the flick of a flat blade screwdriver or case cutter blade. That glue doesn't like the cold. Done it many times. No power loss either. Great little magnets to have around the shop for sure.
Derrickwade
Illinois
Mike
I agree with mike. I'm a flour miller, so I see these magnets in the wheat cleaning and conveying .
Where do you work?
Professur
I remember them well and fondly. I was a road tech when Compaq sent them out ... talk about job security. Those things went south faster than a pensioner at the sight of snow.
That little trick is about to get tried.
GRX
MD
Unobtainium .... that really nifty tungsten-titanium matrix with anti-gravitational properties, that when combined with gravity blocking Cavorite, is indispensable for Anti-Newtonian propulsion systems. :cool:
W
woodgate
Ok when i said i didn't know who was messing with me...I did at least realize "unobtanium" was a joke. I just didn't know how 10 different people had 20 different uses for the same magnet. I guess they are just used all over the place?
Also "unobtanium" gives me an idea to start a new thread for people to give me ideas to mess with my students....blinker fluid, striped spray paint, left handed screw drivers etc etc. I'll start it soon that'd be funny!
W
woodgate
What would I title a thread where people donate such ideas, is there even a name for those? ex. muffle bearings etc.
