Sioux 1287 Air Sander Rebuild
I picked up a 1287 sander/grinder from a yard sale for $1. It works and it's in decent shape once you get past the years of dirt and grease. I can't just use it as is though. Need to tear it apart, clean it, lube it, and replace any o-rings and gaskets.
This is the version without a trigger on the bottom. It has a thumb throttle on top and two screw stops that I guess are to access/remove the throttle mechanism. I separated the throttle handle from the exhaust housing and removed those two screw stops. I thought I was careful to catch any loose parts but while I was cleaning and turning it about, I discovered this part on the bench. I assume it came out of one of those two screw holes. It looks like a check ball but it's not completely round. It's flat on one "side". Not the best photo but hopefully you can see the flat spot.
I did locate a parts diagram but it's not for my specific unit. The one I found only has one screw stop on the bottom and mine has one on the bottom and a smaller one on the side. Anyone know for sure if this is a check ball or some other part I need to re-install? Don't know what it would be called but it looks like it would maybe go in the side port/stop and mate with the the indents on the throttle crank/pin to hold it locked in the on or off position.
I'm also about to contact the manufacturer but you guys usually answer faster... do they make a rebuild kit for these sanders?
