What is this, please?
larry4406
Northern Virginia
Yeah we only use aluminum concrete forms. They connect differently with snap ties, pins, and wedges.
I’ve only been involved with one wood form concrete pour. Was a commercial job. I don’t recall details exactly but there were solid wires from inside form thru the pour to outside form and round red pin gripper thing.
After stripping the forms a guy with nippers had to physically cut each wire below the surface and then parge it.
I thought it to be an odd method. Granted you could cut the plywood to any height or pitch.
micromind
Fernley, Nevada, about 30 miles east of Reno.
Google image search says a concrete snap tie form wedge
I know them as whalers.
Once one side of the plywood concrete forms are set, holes are drilled in both sides and snap ties are run through the holes as the other side is set. There are plastic cones on the ties that hold the inside of the forms.
The ties stick out of the outside of the forms about 4" and basic standard 2X4s are positioned above and below the ties. Whalers are used to hold the 2X4s tight to the outside of the forms.
This way, the forms stay in place and don't bulge out when the concrete is poured. You'd be surprised at how much force wet concrete can apply to forms, especially on high walls.
