Hi All,
I am looking for a tool that I assume exists but that I cannot find because I am not sure what it is called. It would essentially be a portable press that would allow something to be pressed off of a shaft when there is only little space on one side of the thing being pressed off, essentially unlimited space on the other side, and an obstacle preventing a typical puller from being used. An example would be something like a tire rusted onto a shaft of a snow blower where it is desired to pull on the hub of the wheel close to the axle but the outer portion of the rim and the tire get in the way.
In its simplest form, the tool would look like a deep C-clamp with a fork on the fixed side and the swivel removed from the forcing screw. Using the tire example given earlier, the fork would fit around the shaft behind the tire, the tire would fit inside of the throat of the clamp, and the forcing screw would press against the axle. Information on the identity of this tool would be appreciated!
