What is this?
Milton Shaw
It's made to drive old solid grease out of stopped up fittings so that you can grease them. Fill with grease, then hit with hammer to drive grease through the fitting.
Bruce Lancaster
I have a closely equivalent KD one. KD said to use oil, and it works fine. Probably capable of driving lubricant right through a brick wall...
Does yours say KD anywhere on it? I am wondering if it might be an older version made for the pre-1935 type Zerk.
I also have a smaller similar tool that is pretty much a hammer operated hypodermic syringe! It was made to inject glue into loose pockets of wood veneer.
Big-Foot
Midlothian, TX
Yep that's what it is... Don't even think about using it on a zerk that is anything other that straight in. Use it on an angle zerk and you'll be trying to figure out what size EZ-out bit to use on the threads...
These were great to use on trucks with straight axles with king pins that wouldn't take grease.. I haven't seen one in maybe 30 years and it was probably 10 years before that when I last used it..
C
coconanipoo
Southern California
The info you all gave me helped my find the patent on this tool. It is a Duro Grease Ram early 1930's
Thanks
