What is this
zhome888
I got this with a bunch of other tools. What is this?
The Cobbler
My Dad had one, I remember him heating it up on the burner of our natural gas water heater . My uncle owned a plumbing & heating shop, they had cast iron furnaces to put them in to heat them.
MikeF2316
Thornhill, ON
We used this type of iron in grade 7 shop class to solder corners together on metal trays we cut out of mild steel sheet and bent up on a small brake with some hand fitting in the corners before the soldering. They were heated over a natural gas flame.
Stuart in MN
Minneapolis
I did the same thing in the same grade. 45 years later I still have that tray down in my workshop. :)
bonneyman
Desert SW
My dad also used one. Got a steel pail of wood chunks burning, and let the solder iron sit in the layer of red coals at the bottom. When it was ready, he'd pull it out, wire brush off any carbon and debris, and solder his cooler jacks and roof scuppers. Used muriatic acid to eat away the zinc first. He had to move fast as that work would draw the heat out of the soldering iron fast.
