What is this!
shinnen
Hi,
I'm hoping someone will recognize this piece. My neighbour borrowed our pressure washer, and when she returned it, said that she had found this on the ground, near were she was working. I have NO idea what it is. Does anyone recognize it? It's 1 1/4" long (just over 3cms).
Any help is appreciated.
.... john
shinnen
What was she washing? It looks to be a check valve from something, maybe a cloths washer?
lg
no neat sig line
She was washing her deck. It might well be something from her stuff. I was thinking it might be from the powerwasher; but I can't see where it might fit.
....... john
shinnen
1 1/4" long is not near long enough to be a sink stopper. I think when the PW gets fired up again the origin of that part will be come evident.
Hi zeke,
Well, yes, and the powerwasher is leaking in the handle. I'm thinking though that that's caused by old O rings,
which I'm going to replace. And ..... it would have had to been taken apart, which it has not.
.... john
no704
Gas pressure washer? Looks like the check valve out of a “eco” gas can spout!
alfadan
Augusta, ks
hmm, maybe something like a drain plug from some kind of outdoor stuff she has like lawn furniture or kids' toys.
shinnen
If you keep it, you’ll never figure what it is or where it fits. If you toss it, you’ll quickly find where it was supposed to go, and that it’s NLA.
Choose wisely…
Ain't that the case!
..... john
30-30remchester
In the early 1970's Ford had a plug installed into their automatic transmission dipstick tube to keep any debris from entering transmission during storage. After assembly, the dipstick was installed and the plug was pushed out the bottom and remained in the pan where it stayed till the first transmission oil change and then it was thrown away. This looks similar. Like a champagne cork with a rubber o ring.
Snip's
Here is a pic of a part on my pressure inlet check valve... Looks different but similar???
There is also a spring involved... Make sure that's not missing as well...
racecougar
Missouri
Ford did that well into the '90's at least. It's similar, but not the same.
shinnen
Hi Snip's,
"... pressure inlet check valve..." from what?
... john
shinnen
Hi Eric,
I haven't found one so far, but I'm not finished looking.
.. john
racecougar
Missouri
And where does that go, in the wand, in the hose (to or from) the pressure unit? Could it fall out when one of the hoses is disconnected?
...... john
It should be within the valvebody on the pump. Are you missing one of the threaded plugs on the valvebody?
shinnen
Not that I know of. I have a leak in the handle (wand) of the pressure washer but it couldn't have come from there. I'm thinking that this is a red herring and has nothing to do with any of my equipment.
Thanks for your help.
