What is this?
bob from indiana
harrison county indiana
I was recently given a tool box that belonged to a friend who has passed away. I am honored to have some of his things.
I do not know what this tool is or what is is used for. I am confident the knowledge base here can help identify it.
Thanks
Bob
micromind
Fernley, Nevada, about 30 miles east of Reno.
Agree, it's a manual saw setter.
It will bend the teeth os a saw blade or and saw just a bit in order to make it cut a bit wider than the blade. You need to set every other tooth then flip the blade around and do the remaining teeth in the opposite direction.
If a saw is not set or not set enough, it'll bind up when it cuts
PCustoms
VT
So if the teeth are not offset, is it off set?
