What is this?
skullhead
Franklin, TN
Not sure if it is part of something or a tool but I feel like it is supposed to attach to something. Found it in my fathers tool box, he was a machinist if that helps.
I know the minute I toss it I'll be like, oh that's what it is for!
Firebrick43
West central Indiana
Unthreaded pipe bushing. Say you want to put your DWH or boilers pop off valve into a cast iron drain, but is still easy to remove/replace the heater so you don’t need the cost/complexity of a union.
Milton Shaw
I have a set of pipe dies that have those bushing in each size as the dies. They serve as a guide bushing to start the tread straight on the pipe. This set of dies have two piece dies to fit the die stock, not single piece dies or 4 piece dies like Ridgid die heads. Each die has a mark to set the correct thread in the die stock.
Muckin_Slusher
Abitibi
bingo (I think).
I've seen the same thing on Reed dies.
