Hey guys
First off a big thanks to this forum and its members for being such a great source of ideas and inspiration for setting up my compressor workshop. All of the things i've done to try and ensure i get dry clean air has been taken directly from this forum.
Right. there are a few things i wanted to run by members of this forum about my modified set up/ I have uploaded photos so you can see.
The first question is regards 'check valves' or 'non return valves'. As you can see i have cut the air delivery pipe to run the output of the compressor pump through the condenser/rad and then back in to the receiver tank via a water trap. I decided to add an in line check valve after the initial U-bend right up near the head of the compressor pump with the idea being that any moisture condensing further up that run of pipe near the condenser wont work its way back inside the pump!
However, i'm now concerned that the check valve i have added (about 10" up from the compressor outlet) will interfere with how the main check valve mounted in to the receiver tank is able to unload the residual pressure via the pressure switch relief valve. I understand that normally this expels remaining pressure in the pump and delivery pipe so that the motor starts off load. But now the system will bleed off from my check valve and not from right up at the pump. Could this potentially damage my pump and should i remove this check valve??
I have also noticed that since doing this mod the pressure switch relief valve blows off pressure for a much longer time then before but i am assuming this is normal as it has all the pressure to drain from the the condenser and additional pipe??
Despite doing all this however and even tho quite a lot of moisture accumulates in the water trap after the condenser there is STILL quite a bit of moisture coming in to the receiver tank. Tho i must point out the only time i notice this is when it is very hot and humid outside.
To combat this i want to build & install and inline desiccant dryer. I am copying almost completely 'HAP's design featured in another thread. (I salute you sir
I can buy a 40" length of 2" diameter copper pipe from my plumbing merchant. All i really want to know is this. I can either make one very long dryer from the whole 40" length placed on the main drop leg before my filter/reg OR cut it in two and have two smaller 20" dryers one placed immediately after the water trap after the condenser and the other on the main drop leg before the filter/reg as i would with the bigger length.
What would be better out of those two options in terms drying my air before it hits my gun????
Any help on any or all of my questions would be very much appreciated
