What is your oil changing system and setup?
thool
Rochester, NY
I change oil in 4 vehicles, a lawn tractor, a snow blower, and a pressure washer. Right now, I have a oil collection pan and some funnels in one place, the oils in different places, oil filters in another place, and tools/towels somewhere else. A lot of my time is spent gathering and then putting back.
I'm looking for ideas on simplifying the process, or at least consolidating. One idea is to have a metal tray or shallow box for all oily parts, and then a single cabinet with all the oils and filters arranged by engine.
Seeking input, thanks.
kaymccampbell
Upstate New York
You've figured out what you need. Now all that's left is implementation.
Pick a couple shelves in a cabinet. Get a cabinet if you do not already have one.
Set enough oil for a change of each vehicle, with a filter in front of it, in rows across the one shelf. Label them for application if you like.
On the shelf below lay a couple rags and set your pan with slighty oily stuff on that. Then a bundle of clean rags next to it. Maybe even a dedicated set of filter and plug wrenches as well.
Voila! Oil and filter change station!
mrvm
PA
I would suggest building a purpose built oil change mobile cart like the black $99 HF 4-drawer cart. This has enough room to store the oil, filters, rags/towels, waste pan and drawers to organize your sockets+ratchets, wrenches, oil filter wrenches and miscellaneous tools. Small investment for mobile organization or a oil changing "crashcart" for multiple vehicles.
brycez28
Sheboygan, Wisconsin
I keep my 12 quart oil drain pan in a shallow, clear plastic tote with a lid. Fits perfect! I keep my oil filter wrench and a rachet and sockets sizes I need in there as well. Any decently clean paper towel I use during the oil change (check oil level, clean off drain plug, wipe hands, etc), I throw in the drain pan and plastic bin to soak up any residual oil. I keep ALL my funnels in a cheap plastic tool box. Any filters that are for a designated purpose (transmission fluid, oil change, etc) and need to be kept clean, I put in gallon size ziplock bags. If I use the funnel for transmission fluid, I put the paper towel I used to check the dipstick into the funnel to soak up the oil while in storage.
ovilla
Plainfield, IL
I work on and change the oil for 9 cars and 2 bikes (all family) on a regular bases so I'm actually in the process of setting up my own little Jiffy Lube in my garage. A dealer was closing so I picked up three 50' oil hose reels with guns and just recently bought one pneumatic pump to use with a 16 gal drum. I found oil to be much cheaper when purchased this way and I should be able to go through quickly too. Anyway I'm in the process of getting things set up for 5W-30 use right now and if all goes well I'll be setting up the other reels over the winter. The plan is to install everything in the garage attic so I take up less shop space. I've also been going through a lot of windshield washer fluid lately and have been thinking of setting up a hose reel specifically for that use too.
Sent from my iPad using Tapatalk HD
matt_i
I would advise against windshield washer fluid distribution. The methanol alcohol in there is extremely corrosive, even to brass. I once worked in a plant which handled this fluid and there was constant changing of parts from brass to 316 stainless steel.
However with the right plastics, its harmless and benign. I just pour out of the jugs that it comes in.
