I have geo unit sitting on a regular condenser pad. It appears to be similar to the Polarpad version.
I've run geo for awhile and used the same pad with different units. Noise and vibration from standing base aren't really and issue with these units. The main noise is compressor related.
I had an early version that was a two stage piston pump. Case insulation on that thing was an afterthought. It made plenty of racket, but it wasn't from sitting on a pad. In fact, I raised it up and put cork - rubber anti damping under the unit hoping to quiet it down. That didn't change sound levels that I could verify.
With that old clanger banger unit, I ended up doing a light frame around the thing that I lined with unfaced insulation batts. That little trick helped cut down noise levels considerably.
My newer units have been pretty quiet. They are mounted on the same HVAC pad setup used on the clanger-banger.
Speaking from experience. I would mount on a pad just get the unit off the floor. I had a water heater pop in the mechanical room. It was adjacent to the geo unit. The water heater blowout ran full bore for awhile before my wife got the water shut down. She says the water was only an inch deep before running into the drain. Water stains on the wall say otherwise. Either way, the geo unit was not damaged sitting a couple inches up on the pad.
Put it on a pad just for the extra insurance.
the first geothermal I had in this location was in the 80s and it was a FloridaHeatPump,made right in this town.
The second was a Bard,I think built in Wisconsin.
That one has a scroll compressor,the FHP one was reciprocating.
The Bard must operate on a different harmonics,as it will resonate and of all places I hear it is on 2nd fl master bath.
So the sound is traveling thru the all concrete basement,thru the concrete floor of the 1st fl. Im guessing its using the
drain pipes in bathtub as a conduit. Dont get me wrong its not that bad but might as well try and improve it.
The manufacturer of the one Im having built,has a sound/insulation upgrade option for $100,
which I chose but imagine its just a blanket over the compressor.
I would like to find a 1 inch rubber pad,24x24 or 24x26.Been thinking of those horse stall pads they sell at Tractor Supply
but way over kill on size. Making the wrong choice here will be a big PITA to replace if this pad falls apart later.
Im going to call Amazon Rubber here locally. They arent related to Bezos and have had that name for hundreds of years.
