ymurf
What jack stands are you guys using with your Maxjax? I think I would feel safer with a couple jack stands but doesn't seem to be a big market for 36-48" jack stands. Or do you work under them without and safety measures?
They're for extra stability if you're really going at it or if you're removing an engine/trans/axles and the weight is going to shift significantly. Those OTC style ones are good if you have to hold up an exhaust or diff housing or something, works as an extra set of hands.The whole point in spending thousands of dollars on a lift is so that you don't have to screw with jack stands any more.
I don't use anything with mine. I just had my car up there for about 3 weeks while I rebuilt the entire suspension. No problems.
I have those gregsmith exact stands......I just assembled them and I can't figure out something with the screw in top extensions....There are 2 large washers and a ball bearing washer piece but they do not lock in place at all and there is no other pieces in the shipping box....I was hoping someone could give me some explain on assembling these.... The directions stink...thanks so much!
