What kind of a nut does this remove
Shade guy
arizona
BFBOB
A BIG one!
Looks shop-made to me, to reach a nut that's recessed; maybe a locknut on a pin on heavy equipment? Front loader/excavator arm or the like?
lis2323
Most likely for removing a “spline head” bolt for wheel lugs.
Jbullfrog
Avoca, Iowa
Based on the length of the handle, I would say a spindle nut within a hub. Gatlibs's link shows a tin castellated lock cover, on a 12 point spindle nut. This wrench would be used to turn the nut after you removed the locking cover.
KnurledNut
n/a
It would have to be a low torque application, as the bi-hex is only plate steel. 1/4"?
What is the dimension across the flats?
Definitely looks shop made for a specific application, perhaps industrial or heavy maintenance.
