worriedshrimp
- Joined
- Oct 28, 2013
- Messages
- 15
greetings GJ,
i'm building a table top that one end (approx 1/3) will lift up with hinges. the table top is two 3/4" pieces of birch plywood glued together for a total of 1 1/2" thickness.
the portion that lifts on the table is heavy with 1/2" rubber matt glued to the bottom. a standard piano hinge will not be adequate.
i would like the seam i cut and the hinges i install to be as flush as possible. i'm trying to find the correct - offset x 1 1/2"? -hinge and use four of them across the 36" width of the table.
can anyone describe the type hinges i need for this job and where i might find them?
thanks for any input.
tws
tws
