What LARGE reversible ratcheting wrenches to supplement Snap On sets??
Mohawk Dave
SoCal
I picked up the Snap on reversible ratcheting wrench sets. (Very nice btw, much smaller heads than my GW)
But they top out at 19mm and 3/4". I work on a myriad of stuff, and would like to keep going up the size chart.
I have some large non reversible GW 1", 1-1/8", 1-1/4". They are nice as well, and I'm not certain that reversible is needed in these larger sizes.
I looked at Williams reversible, but the 21mm, for instance, is shorter than the Snap on 19mm, which would bug me. 1 for function, because that's a large fastener, and 2 for looks in the wrench rack.
GW reversible stuff is pretty much in line with lengths close to Snap on.
I saw some Proto out there as well.
So, those with the Snappy sets, what brand do you supplement the large sizes with?
hautpot
California
Sockets:lol_hitti
But the non-reversible end at 1 inch and 24 millimetre. That is of course.... if you are only after Snap-On.
Your best option would be gearwrench
JonDick13926
Sidney, Ohio
I have the Snap On set too, and I have an 8mm Williams wrench that is nearly identical in design to the Snap On wrenches, except it's made in Taiwan. I just checked, and those same Williams reversible wrenches go up to 25mm and 1". Check out their catalog.
Just to add, I found the 4 piece set on Amazon. Not sure what you're budget is here, but it's $109 for the metric set.
http://www.amazon.com/dp/B002N7T3N8/?tag=atomicindus08-20
Found the same set in Gearwrench for $96.
http://www.amazon.com/dp/B000NICH3C/?tag=atomicindus08-20
GTA Matt
Zebulon, NC
I have the gw set, 4 or 5 sizes, 21mm and up. Quality is fine, probably the best value out there for ratcheting wrenches that size.
