sfm1951
What brand of down draft do you autobody guys use? Air make up, Heat and cure. Pros and cons. Thanks, Steve
I've been this bad and made it work:
Here is my temp booth made with PVC that is held together with screws so you can take it part.
Wife taping it up.
Pic of booth before opening was covered worked ok for the color but not for the finer clear. Also you can see the paint rack I made for the parts. My son in law doing the painting.
Exhaust fan from harbor freight, I put a filter on that side too. I put it in the window, close the window down .
It works really good and keeps the stink out,even works on clear coat. Tried it without the cover on the opening and it did not have enough seal for it to be pulled out through the exhaust fan.
