What R value to blow in ceiling?
estesbubba
My pole barn is going to be used for a hobby woodworking shop. I'll keep the temperature around 40-45 when not in there and 55-60 when working in there. When I need to spray waterborne finishes I'll get it up to 68-70. I plan on heating it with a propane ceiling mount heater.
My walls will be R-19 and the bottom of my trusses are 2x8's. My ceiling and walls will be 7/16" OSB. What R value should I do for the blow in ceiling?
MScott
Eastern Ontario
Or put your location (state, province, country etc.) in your profile. Any answer to your question is useless without your location.
LB-1911
Northwestern Il.
Omaha, NE area which is zone 5.
What are the dimensions of your structure?
Have you considered partitioning off a section and use it as your spray booth?
readhead
Durango, Co.
Is the heater a sealed combustion unit? If not it can put a lot of water in the air. I would put at least an R-30 in the lid.
As much as will fit and you can afford.
That is a SERIOUS reply ! With ceiling insulation, MORE is always better !
Cjk
Wisconsin
I put R60 in mine. I have a steel ceiling, trusses 8' on center and the builder wasn't concerned with the weight. :dunno: How far apart are your trusses and how much weight can OSB handle per sq/ft at that span?
Steevo
43.49600, -112.04300
I am in zone 5 also (eastern Idaho) and I went with R21 in walls and R60 blown in (18" of cellulose) in ceiling.
It is excellent, requiring very little gas to heat in winter.
