HOLY JUMPIN GEEHOSAFAT! Have y'all seen the prices of florescent lights!!!!!
What's the correct T8 ballast to use with a single 4' bulb?
I going to have to do some cost comparisons. Maybe a jury rigged reflector of some sort.
If they are going to be run a row, use a 2-lamp ballast.
or 4 bulb with one ballast in a row is another option
Can that be done with sayyyyyyyy 5' between them? Same ballasts as cybrdyke referenced?
Max ballast to lamp distance is 20' with 32 watt lamps. Remember that's feet of wire length to the furthest point, not "as the crow flies", so if you have wads of wire inside the fixture, you wont make it.
Put the ballast in a master middle fixture and go 2 slave fixtures one direction and 1 slave fixtures in another direction.
The ballasts are now ***-4P32-***.
You could also do 3, ***-3P32-***.
Or 2, ***-2P32-***.
CD
