What say you about this grinder?
RivennHewn
PNW
For $150, I'd buy two Makitas.
I always have two grinders. One for metal, and one for concrete.
The concrete dust eats them up.
C
cashishift
Omaha, NE
Looks damn **** to me i`ve always used Bosch tool with never a problem bought my first drill at 14 still have it!
Well, I used to be a diehard dewalt guy.. the DeWalt one is nice too, but this one is 40 bucks cheaper.
I got one Bosch Jigsaw.. now I'm starting to bleed blue or yellow :lol:
C
cashishift
Omaha, NE
Once you got used to the idea of not changing the wheels. I'd find having a few of these is quite handy.
sure sure.. but for right now, one will be fine.
my main motivation for asking for one of this style vs the cheaper ones is i have a porter cable buffer that is the barrel grip style.. and I prefer the trigger switch vs a slider switch on my buffer.
Seb650R
Houston
It looks pretty slick. If you look around you can also get the Dewalt 4 1/2" for $70. That's what I have and it is a solid piece of equipment. I guess its just a matter of preference. :dunno:
mtnkrake
I have one. I got it on a blow out sale for 65$ or so. Its a good comfortable grinder. The trigger is a little weird the way it locks.
Chadwilliam1
Cincinnati
I have seen Bosch grinders that wouldn't die and others that were junk and didn't last but a few months. I prefer matabo, that have never let me down. They are a little pricey but they will last a very long time.
cheechi
Triad, NC
I would get the PC version until you get more of an idea of how long they will last you. May not be worth spending $100 if you will kill it in the same time you'd kill a $40.
Don't get me wrong I like it. Just would be pissed if I bought one first and found out I'd go through them quick.
lotsoftools
Inland Empire
One of the guys at school has that grinder and it seems to work good for him. I think he is taking 3 classes this semester, so I know it is getting some good use. It hasn't broken so that is a good thing.
mtnkrake
THis unit does have a locking trigger by the way. Its a little tricky locking and unlocking though.
sberry
Brethren, Michigan
That is a 5 inch but the very best deal on small grinders bar none is the B&D 7750 from Walmart for 30$. Worth 10 of the HF ones and almost as good,,, maybe better considering the cost as expensive ones. Other tools I buy up, this particular one its all we use anymore.
I can say this about this tool without blowing smoke out my ***. I can see some part timers being wide eyed at the HF stuff, but they have 3 or 4 units, split the use on a Saturday morning, of course it lasts a long time, light load, low hours. If a guy would put an hour meter on one you would be surprised how low, only in professional shops do they see real use. Doubt a guy could wear one out on a car, usually isn't outright wear that kills them **** a fault combined with heat. Most operators are not strong enough to overload it and most home/diy types are timid enough they don't pick it up and bear down on it hard enough and definitely not long enough to overload it.
I stood on ladder the other day, ground about 3/4 inch weld off on a crane about 2 ft long, smooth in about 30 mins. It was getting warm, so has every other grinder in this class, if I wanted to could overload it for about a minute but this wasn't minute job, at some point a guy is only strong enough for so long.
Point is, over 30 yrs, maybe more have field tested a lot of grinders, not every one, haven't wore every one out, some broke, some damaged, nothing smarts like your new grinder being rolled over by a pipe, ha.
This grinder resembled an industrial model, it was the 2750 with paddle switch, had several, even bought 3 at once when use was hi the brushes were a weak spot. , anyway am stumbling thru Walmart, had heard these were good, picked one up and was impressed by the weight and feel, I like paddle but thought wtf, it ran nice, tossed it behind my pickup seat bought another and said, lets put this pos on the bench. I got another one there, used about 10% when we cant find this one but told my men, use this one. We use a lot of used materials working on well used machinery. Not only is it not used as a "part time" tool it is used by multiple operators.
I got some Makitas, I got some red, yellow, blue and a few black. Will trade any of them even up for this. 5 years as near as I can figure, thousands of cycles, probably sharpen brush hog blades 75 times alone which if I didn't do anything else would have made the raw tool cost about a quarter a use, but thousands, some easy but some heavy weld removal too, never overheated it, not a problem including,,,, cord, had first problem at 5 yrs with a switch and was going to toss it, my guy says, let me take a look, turns out it was repairable and the brushes still look 50%, another couple years it died again, didn't smoke, just quit, I figure its the switch, didn't look, replaced it in about 30 minutes, had someone near a store.
I usually remove broke tools, this one still here gonna play with it if I can remember. I want to drag out box of old 2750's, DeWalt 402 the chassis looks identical, I wanna take back plastic and paddle switch and stick on this cheapo.
Not all cheap tools are good but I think here was a case they copy an existing line in the industrial, they try to make it cheaper, due to technology, improvements in materials and a little design that worked in their favor the consumer version turned out way better than the original ever was minus the paddle switch feature,,,, which I am used to, not perfect but not a deal breaker.
I am almost in about a year and a half on its replacement, so far its running me about 5 dollars a year for a power tool we use daily.
Even if a branded deal for 150 would have lasted twice as long,,,, which hasn't been my experience with this particular tool, would have cost 4 times as much.
sberry
Brethren, Michigan
While they work and work well I don't care all that much for wire wheel on eletric. Main benifit to electric in these types of tools is cost and operating cost. Air uses 5 or 6 times the power, puts lots of hours on our small comps for something a guy can do with a 30$ tool and a 5$ cord with less than a thousand watts.
Zeke
I hold a small angle grinder with one hand mid barrel most of the time. The Bosch would not work well for me. Makita with the slide switch is not one of my favorites either. I have 2. But I have 2 HF units with a side switch and I like them fine. The HF nut is bulky compared to the Makita. You want to consider that end as well. Getting a grinder almost to the flat position produces nicer work. I use the biggest one that will fit the job all the way to a 9". Remember that you can put a 5" disc on a 7" grinder, but not the other way around. Not safely anyway.
BMW_Garage
If you're willing to spend a little more I would get a Metabo or even better Fein. They are gonna last you a long time. Very high quality stuff.
Southern
<img src="http://www.revolusic.com/moviequotes/png/0010/"/>
sberry
Brethren, Michigan
It is one of the best grinders around.
Dewalt does not hold up. I have seen so many worn out ones that I would nevery buy one.Then again I don't like Dewalt
The best thing about the 402's, I think they come with a hex spindle nut you could steal when it puked to put on a cheap grinder to replace the spanner wrench. I will agree, I dont think the 4 1/2 was a tool DeWalt ever got right. Basic design, switch was great but they never hold up and who is going to put 75 in a grinder you can replace for 100.
wideopen1967
Check out this site, http://www.cpooutlets.com/for the best price I have found on Bosch tools.
I wrork for a Bosch company and even with the employess discount the CPO cite is cheaper. I have purchased many of their reconditioned tools for work and only had a problem with a battery charger, one email and they had another on the way.
C
cashishift
Omaha, NE
I checked CPO and Amazon is still cheaper.
Zeke
I have purchased from CPO before and had great results. The funny thing is that I wasn't at the time even thinking what "CPO" meant. And I still knew I was buying a reconditioned tool. Makita as it were and I have had not a problem.
So, funny story: I have a bit of a temper. It's gotten a lot better with age. But it will flare up from time to time. I have this Makita tool that I mentioned because I literally beat one with a hammer until it was a pile of blue plastic.
Yes, I'm the guy that got so frustrated with a lawn mower that I started it up, ran it at full throttle and proceeded to beat the engine with an 8 lb. sledge. This was one of the most amazing and gratifying experiences of my life and no one was around to see the carnage. That sucker ran for over a minute while I wailed away until it went up in a glorious cloud of smoke.
Damn, I should have YouTubed that.
DMAR
Hey Zeke, great stories. And that reminds me, we could really use a new babysitter, are you available to watch my kids...?! :lol_hitti. :lol: I'm just kidding with you, don't get mad at me! :lol:
