What screws to use?
brycez28
Sheboygan, Wisconsin
I have to admit, I am guilty of using drywall screws for almost everything I do. I am going to start making some wall cabinets for my garage out of 2"x4"s and plywood; I'm tired of shelves with warping boards. They will probably be around 5' long, 12" deep, and 30" tall with a center shelf and open storage space above. It will mostly have all my cans and bottles of garage supplies, but will also hold miscelanious car parts and a couple spare batteries I have. What would be the best type of screw to hold the cabinets going into the wall studs?
kbs2244
I have done many a shelf unit like that with 2 1/2 or 3 inch drywall screws.
nolimits76
Oklahoma
I have also built several shelf units with the same screws...no problems.
Last set I built measured 4' long x 2' wide. I put them against a corner in my garage so they had 2 sides I could attach to the wall. Frames were made of 2x4 and I also placed an extra 2x4 support at the mid point. After I built the frames I attached to the wall then came back and added a front support leg on the left front corner (floor to top shelf) to give a little more stability. Finally, I cut 3/4" plywood for my shelf decking. Everything was attached with the 3" drywall screws and the thing was ROCK SOLID!
I made my old work bench the same way and it too was rock solid. I've had 500# on top of my work bench before with NO problems.
So I'm a believer. Although I think a large part is how you construct the frame, etc.
~smokey~
If I'm not building stuff using drywall screws I'll use gold deck screws, the large one on the left is 5" long and has more agressive threads, it's a #2 robertson but even larger #3 robertson's are available, nothing I've ever built using screws has ever come apart.
djjsr
In the cornfields
Don't use drywall screws. Use the proper screw for the job. Cabinet mounting screws can usually be found locally or if you can wait, McFeelys is a good source.
They have a large diameter head that will not pull through the back rail of the cabinet. I recommend the square drive over the Philips. Much easier to install.
edit - I just re-read your post. You're going to use 2x4s for the cabinet frames? You might be better off using long lag bolts with flat washers under the heads.
dwm
Southeast Michigan
I would personally use French cleats to put the cabinets on the wall. Lets you take them down fairly easily later if you need to for whatever reason, and gives you the option of not having exposed fasteners inside the back of the cabinet. Easier to get the cabinet on the wall (no waiting for your partner to drive screws while you hold things up :)). Inexpensive. Can be made with a table saw or a circular saw with a good guide.
kbs2244
Cabinet mounting screws are nice if you can find them.
I use the more common drywall screws with a washer under the head.
Fixnair
Sapulpa OK
Drywall screws have very little shear strength. They should not be used for general construction. Any lateral stress and they will snap because they are so brittle.
