No asian ****.
That pic shows what I was trying to explain. It is so much easier to explain it when I have all the couplers in my hands and showing the customer the differences.
We generally sell M style, A style, L style, T style, and P style. We also carry Big Flow couplers and plugs.
Your pic of the 3/8" with 5/16" bore is our P style couplers and plugs which are available in 1/4" and 3/8" pipe size.
Cool. Maybe I can learn something (not always easy for a dinosaur).
The reason I posted the first photo showing 1/4" and 3/8" couplers was because I didn't understand this part of what you said:
If you have standard flow couplers and plugs and you switch between 1/4" and 3/8" there is no difference in flow therefore no difference in performance because the hole size is the same.
I'm guessing you meant the 3/8" couplers on 1/4" fittings, which is sometimes done, and doesn't help airflow, just as you said, but not what I was trying to show.
Anyway, I've never heard the couplings referred to by letter codes and I can't find them in the couple of industrial supply catalogs I looked in. The ones I'm most familiar with are "automotive interchange" (what you called type M, and sometimes called Tru-Flate) and "industrial interchange" (sometimes called Coilhose).
Can you explain or show photos of the M, A, L and T styles for comparison? Or whatever is commonly recommended?
Here's what we use:
From left to right:
1. Old-style Binks. Has a 1/4" bore, compared to the 3/16" bore of type M. We still use these in the paint booth (separate clean compressed air supply).
2. Industrial Interchange (Coilhose). What letter style are these?
3. 1/4" Automotive Interchange (Tru-Flate or Type M).
4. 3/8" Automotive Interchange.
