Hey guys, hoping someone can help with an answer to my predicament.
We bought a house with a detached gable style garage about 6 months ago. If I understand correctly (and there's a good chance I do not), this has a ridge beam and rafters that place the load on the 4 exterior walls. It then has a middle beam that runs parallel to the ridgebeam and then ceiling joists attach from the exterior walls to this middle beam with joist hangers. Drywall then hangs from these ceiling joists and plywood is on top of the joists for storage
This beam looks like it is made from 2- 2x12s and OSB sandwiched between the two. There is a spot where this was lengthened with a spliced segment and that area looks like it is starting to sag and the drywall beneath is starting to crack.
I want to replace this beam but I am wondering how large of a beam I need to span this 24ft width. I would like it to still be able to support the plywood sheathing for storage and want it to be sound. I also don't have $20,000 to spend on this.
If the load of the roof lies on the exterior walls, to replace this beam could I build temporary support walls parallel with the beam I am removing on both sides of the beam, detach the ceiling joists and install the new beam, followed by reattaching the ceiling joists?
Thank you for reading the long post and for your help!
