VietGnome
I'm deep in the planning process of my garage build this summer.
I was originally planning 4x 240V 50A circuits. Heatpump, lift, welder/compressor, and EV. I don't own any of those currently, but I'd like to factor it into the build since it's easier now than later.
I was originally planning on running every circuit at 50A. But apparently running 6AWG all over your 1200sqft garage adds up... Trying to cut down circuits to 30/40A as required, one of those is the heatpump circuit(s).
I don't plan to finish the garage this summer, and hopefully over the winter/next year I can insulate and heat it. I'm currently planning to blow R40 into the ceilings, and R21 into the walls. I live in Eastern Canada, so winter is real. I'm considering heatpumps but don't know what size. I've scoured some older posts but results vary, and lots of replies are from more temperate climates. I don't foresee me using AC much, but the dehumidifying in the summer will probably come in handy.
I don't want to keep it blazing all winter. I would keep it around 10C and bump it to 15 when I'm working, but I understand heatpumps tend to not go below the 15C range, so that's what I'll settle for. Not sure on sizing, if I should go for a single bigger unit (30k?), or two smaller 15-18ks?
Thanks for any advice.
