What size miter saw for 5 inch baseboard (cut upright)?
dclark2171
My Ryobi 7 inch is too small. Will a 10 inch sliding Miter saw do this? I'm not looking to use a miter box...too much work for my project. A 12 inch seems quite big and bulky. This new saw will replace my old Ryobi. Suggestions?
e015475
Show Low and Mesa Arizona
In an uncharacteristic move for a cheap guy, I bought a DeWalt 780 when I replaced all my baseboards a couple years ago. A 'cry once' scenario and I never looked back. I'm in the middle of another baseboard replacement and a good miter saw is a joy to use. It will cut up to 6.75" with the baseboard stock standing up against the fence and up to about 15" with the stock flat and using the bevel. The only downside with it is it is a PITA to store.
Let's see, half of 10" is 5", minus the arbor nut diameter gives 4 and change inches. I see a fail for a 10" saw, but I could be mistaken.
I guess if your baseboard is thin enough, should be ok, now that I think harder. Still no coffee, so a bit of a handicap right now
I'm seeing 4-1/4 to 4-1/2" depending on brand
Sal Bandini
Why does it have to stand up?
Outside and inside corners are never square or plumb. Cutting angles other than 45 degrees and offsetting the cut top to bottom to close the gap is next to impossible using the bevel rather than the miter function.
D
dclark2171
Hmmm. Is there such thing as a light & Compact 12 inch? I plan on buying a "wheeled" miter stand that fold up
signcrafter
12" would be the minimum.
As noted above, the depth of cut would be half the blade diameter minus half the nut or bearing diameter.
This isn't true with miter saws, or at least mine. The arbor isn't lined up with the fence and mine has more room behind the arbor and will cut 6 1/2" trim standing up with a 12" blade.KIMG20250722_102821822.JPG
readhead
Durango, Co.
Sal, I spent a lot of time as a finish carpenter and I haven’t seen a miter saw that only bevels to 45* in years.
jar944
Northern VA
Not much difference weight and size wise between a 10" and 12" saw, at least not enough to not just go with a 12" saw.
Certainly possible and required for 7"+ moulding
Yup, thanks for clarifying the ability. I was thinking cutting wider material, but clarity arrived shortly after hitting post .☹️
Sal Bandini
I never said 45 only. I said corners are not square so if you get an outside corner so out of square and plumb you have to split the difference and then also shim one end on the saw to close either the heel or toe of the baseboard. That's not easy to do using the bevel function.
Some of the corners in my basement were that bad.
Unless you are painting and don't mind using lots of caulk.
Firebrick43
West central Indiana
4 out 3 people struggle with basic math
Firebrick43
You don’t have the blade fully down in that picture to cut all the way thru
I cut a scrap of 1/4” to 5” tall to demonstrate on my 10” glide.
A 90 deg cut works barely with a piece this thin. But if was 3/4” thick it would hit and kick out the bottom.
A left 45 does not work at all, actually all left cuts will hit the belt guard before cutting completely thru on a 5” tall piece.
signcrafter
Correct the blade needs pushed down another quarter inch. Here is a piece of 3/4" thick 6 1/2" tall with blade pushed all the way down. But you are correct about cutting 45 in the one direction.
MushCreek
Upstate South Carolina
With a good stand, a 12" saw is manageable. I have a Ridgid 12" slider which weighs 63 lbs., but on their stand it's easy to set up and move around. I've timed it; I can set it up in 30 seconds or less. The stand I have has 12" wheels, which is nice on a rough job site.
D
dclark2171
I think I will go with a non sliding version. I only do trim and baseboards with a miter. I have access to a table saw if I need something wide. I'm eying the Dewalt, however, the Metabl HPT is on sale at lowe's and Menards.
WWheeler
Middleofnowhere USA
I just keep my Dewalt DWS779 mounted on a Ridgid AC9946 folding miter saw stand when I fold it down and put it up. Even sliding it in the back of the truck out to a jobsite. I rarely remove the saw from the stand except when I switch it out for my Evolution R255SMS-DB - 10" dual bevel sliding miter that I mounted on the same Ridgid rails just for when I'm cutting metal and I don't like to do much of that in my garage if I can help it to keep down the metal shavings getting everywhere. Sawdust is one thing my shop's pretty setup to deal with, but not metal.
The Dewalt is the best miter I've had at being able to keep it's setup after moving it around a bunch, but still do need to do a quick setup and verify after folding the stand out that everything is still spot on. I use a mini machinist square and digital angle finder. Takes a couple minutes and usually I don't need to adjust much if anything. I had a 12" Ridgid Slider that wouldn't like to hold it's setup throughout a single job without constantly checking/adjusting, much less taking it across town. It was frustrating AF to find just locking it in at 90 wasn't a true 90 anymore when it just was 4-5 cuts ago.
Dewalt-Addiction (3).jpg Evolution R255SMS-DB on RIDGID Mounting Brackets.jpg
tarbellb
Oregon
My money...
Metabo hpt rail forward 12" slider (small footprint)
and
Ridgid HMU rolling base (effective and cheap)
e015475
I'm setting about 300' of baseboard now.
On a side note, if you've not tried thickened CA glue and an accelerator to glue your ourside mitered corners prior to nailing it off, it is a game-changer. Works really well on splicing base together on runs longer than 16' too - can't really even see the joint.
D
dclark2171
I have narrowed it down to the Bosch or the Metabo HPT sliding miter saw. I am getting more into wood projects as I get closer to retirement. For an extra $300, the Bosch seems to be an overall better saw and one that could be my forever saw. No shadow light, however, I can add that later if I really need it. The laser on my cheap Ryobi is useless. I just line the blade up with my mark without the laser.
D
dclark2171
I purchased the Bosch and I am really happy with it. An experienced contractor I know uses both Bosch and Dewalt miter saws and told me pick what ever feels best. He pointed out that Dewalt and Bosch are super easy to find oem parts on Amazon. He told me to buy a nicer blade and I'll be set.
I played around with both the Bosch and Metabo and something "feels right" about the Bosch. After I calibrate and use it, I'll come back to share my thoughts.
Firebrick43
I love my glide as it solid and more importantly sets up against the wall because of the different slider design.
Its one MAJOR flaw for doing trim work, its so heavy that it absolutely ***** to move.
MushCreek
Parts are an issue to consider. On my Ridgid, about 5 years after I bought it I had a board explode and take out the plastic kerf insert for the table. NLA. I made a new one out of polycarbonate. Seems like on a $600 saw, parts should be available for more than 5 years.
tak1313
My money...
and
The Metabo looks interesting, but I can't seem to find the spec on what it can do as far as standing baseboard capacity. I found cut capacities for like 4 1/8 x 12 or something like that, but standing baseboard is a little different because it's usually more since you're just cutting with the rear portion of the blade without worrying about the spindle.
D
dclark2171
i know it's differnt times now, however one of the main reasons my Dad purchased Sears branded power tools, sump pumps, mowers, and appliances is because of parts availability. Dad used his Craftsman 1965 riding mower well into the 1990's and basically replaced every part on it at one time or another.
