What Size Romex for 3-pole
smokey0810
Canyon, Texas
Have a hallway light that runs off two switches, one at each end. Want to add another light in the hall to run off same switches. Will just daisy chain off current light. Just wondering what size romex y’all would use. 12/3 or 14/3….
Shiftless
East Bay SFO
I’m not a electrician, but I do my own work here at the house.
Sounds to me like if you have 2 switches controlling one light fixture, you have it wired up with cable containing 3 wires plus a ground making 4 wires all together, right? Each switch has 3 screws plus maybe a ground screw, right?
To add another light fixture, all you need to do is run cable with 2 conductors, a white and a black plus a bare ground wire, in between the old and new fixture. That would be 14-2 or maybe 12-2.
Shiftless
East Bay SFO
The three way switches don't matter. All you need is a 14/2 or 12/2 between the lights.
Right!
You could have 2,3,4, or 10 switches controlling the light and all you’d need is a length of 14/2 or 12/2 to run between your existing light and the new light. Or two new ones… Or ten new ones.
I have 9 light fixtures in the garage all controlled by the same switch. Each light fixture is connected to the next one with one white and one black wire (plus ground wires)
sparky 1971
Central Iowa
Right!
You could have 2,3,4, or 10 switches controlling the light and all you’d need is a length of 14/2 or 12/2 to run between your existing light and the new light. Or two. Or ten.
Correct. One thing that has to be remembered on GJ is that the simplest of tasks can easily be turned into something more difficult than moving a mountain with a teaspoon.
Jim greengo
Behind my house
If you add a 3rd switch it will be a 4 way between the 3 ways if I'm reading right.
Depending on how things are layer out it could be 14/4 or a couple of 14/3s
mike93lx
Richmond, VA
It’s a 4 wire setup due to the 3 pole switch.
The number of conductors is not size.
Wire gauge is size (12 or 14). If you aren't sure, get 12.
2 conductor is all you need for this if you can get to the other light. You're just tying into the same hot and neutral that is already switched
sparky 1971
Central Iowa
One thing that should be added is that when the existing light(s) come down, there may be more wires in there than what is expected. Do not take anything apart that isn't connected to the lights. I've had many a housewife call me to come over when the husband was gone to work because he attempted to hang a new light and took too many wires apart, now nothing works. The last time, nothing worked except the light, but it wouldn't shut off. She told me he got it that far after tripping the breaker at least four times and called it good enough, he would fix it when he got home that night.
Whoever (it honestly wasn't me) wired my family room and dining room ran the travelers through the ceiling box. Both were also set up originally as ceiling fan with lights, the ******** used pancake boxes, then didn't keep the colors consistent. The other rooms have the 120 run to the ceiling box, a switch loop down, and all the receptacles fed off of it. It can get confusing, but if the only wires that get touched are connected to the light, all will be ok.
CJ7VFR
Central New Jersey
Yes, ceiling ******* usually come in pairs. Wait, do I have that right?
What is funny is that once you hear the term ******* used to describe those types of light fixtures, you can never, ever forget it. And every time you see just one of those light fixtures in the ceiling you always ask yourself, hey, where is the other one?
Jim
